Problem...
Old Sep 21, 2004 | 06:42 AM
DJy's Avatar
DJy
Default Problem...
Hey guys,
I have a 94 ES and when I make a hard left turn there's this high pictch screeching noise. Even when I'm doing a U turn. I'm not sure what the problem is but it seems to be coming from the tire or around that area. I was going to bring it into the dealership but decided to ask you guys for your opinions. When I do a hard right turn there is no noise. Has anyone every had this problem? or what is the problem? Thanks.
Old Sep 21, 2004 | 09:27 AM
lexusk8's Avatar
lexusk8
It would definitely help out if you can be a little more specific about that "screeching" noise. Maybe next time when you take your car out, roll down your window and make your turns to determine the accurate location of the noise. It could also be coming from the power steering pump, but hard to tell from the description you provided.
Old Sep 21, 2004 | 01:03 PM
TLW's Avatar
TLW
maybe and im saying maybe
are the belts tight
i cant remeber if you guys have a couple of belts or is just one
if its the power steering pump there is a company called Lucas that makes
a great product
Old Sep 21, 2004 | 05:29 PM
DJy's Avatar
DJy
Thanks guys. I'll try to pinpoint where the noise is coming from and I'll look into the power steering pump. Thanks again.
Old Sep 21, 2004 | 07:29 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Default Re: Problem...
Originally posted by DJy
Hey guys,
When is the last time you checked the power steering fluid level? sounds like your P/S is deprived of fluid. Make sure you check it ASAP, otherwise you'll damage the pump and the rack. Very $$$$ items.
Old Sep 21, 2004 | 07:30 PM
flipside909
Lexus Connoisseur
25 Year Member
are the belts tight
There is only one belt for the P/S in the ES.
gs300by
Jan 6, 2016 05:24 PM
knocker
RX - 1st Gen (1999-2003)
Jun 30, 2011 03:09 AM
lil23pinoy
Sep 27, 2010 09:29 AM
TJW98LS
Oct 9, 2005 01:29 PM
VSsc400
May 10, 2002 06:40 AM
