Check Engine Code
Old May 13, 2004 | 03:52 AM
carcass66's Avatar
carcass66
Default Check Engine Code
I heard that you can jump the diagnostic port, turn on the ignition and the check engine light will flash a couple of times giving you the code. I don't want to waste $40 for diagnostic reading..if someone here knows how to do it pls. give me the complete details. Thanks.
1992 ES300
Old May 13, 2004 | 05:36 AM
flipside909's Avatar
flipside909
Lexus Connoisseur
Default Re: Check Engine Code
1992 ES300
You can only do it on California sold vehicles with California emissions equipment unfortunately.
Old May 13, 2004 | 09:37 AM
link13's Avatar
link13
Actually, I believe that vehicles in all 50 states comply to the same standards with regard to the EFI diagnostics stuff. There may be some differences with emissions equipment, but that does not affect your ability to pull check engine error codes. I have found the following document to be very useful in terms of its explanation of pulling check engine codes on OBD1 (pre-1998) cars:
http://www.autoshop101.com/forms/h27.pdf
There are references to older, mid-80s Toyota vehicles in the document, but I believe that the principles of pulling the error code still apply to your car. I have an intermittent check engine light on my own car, which I will be the pulling code on very soon. Good luck, CL brother.
Old May 13, 2004 | 10:08 AM
flipside909
Lexus Connoisseur
Any OBDII equipped vehicles cannot use this method to check for codes. But I do recall and the last time I checked on newer vehicles 1990 and up, the method only applied to CA vehicles. It should state it in the owners manual of your car. The first OBD II compliant vehicle in the world is the 1MZ-FE V6 equipped Camry and ES300 starting from 1994. Obviously the TE1 to E1 method will not apply since you need an actual code scanner to read the codes. The 3VZ-FE 92-93 ES and Camry V6 models are OBD I.
Old May 13, 2004 | 01:50 PM
link13's Avatar
link13
I must have the OBD II and OBD I mixed up. I thought that OBDII cars were newer and that you could pull those codes with a scan tool and OBDI cars required the method explained in the PDF file that I posted. Sorry if I mixed it up. In the case of my own vehicle, the scan tool does not work and you have to jump the T to E1 terminals. It's a '94 GS.
Old May 13, 2004 | 07:37 PM
flipside909
Lexus Connoisseur
No you're right.
Certain OBD I and older vehicles, you can use the TE1 to E1 jumper
OBDII - Scanner only.
Old May 14, 2004 | 04:50 AM
carcass66's Avatar
carcass66
Thanks for the info guys..I also found this website http://www.troublecodes.net/Lexus ..tells you exactly how to do it and what the code means. I'll try it this weekend.
Old May 16, 2004 | 04:42 PM
carcass66's Avatar
carcass66
Well I'm done pulling the codes. First one is the Main O2S and the second one is KS Signal. Anyone knows about KS Signal and what part I should replace to fix it? Thanks.
Old May 16, 2004 | 06:13 PM
link13's Avatar
link13
carcass, try sending a PM to VVT-i. He is a Lexus tech and should be able to help you out.
Old May 17, 2004 | 06:16 PM
steviej's Avatar
steviej
I think the KS signal is the signal coming from the knock sensor. It may be not be reading correctly.
steviej
mtyink
Jul 4, 2011 10:18 PM
aceboogie6
GS - 1st Gen (1993-1997)
Feb 13, 2011 10:28 PM
acc
Jun 10, 2010 09:49 PM
GOLDSc300
Maintenance
Apr 15, 2007 07:32 AM
