Plate screws removal
Old Apr 9, 2004 | 06:14 PM
lxs300's Avatar
lxs300
Default Plate screws removal
Okay! Prev Owner had plastic screwes fixed for plates and when he sold it to me he couldn't take of plastic screws and ripped of plate from screws. Now I can't fix new plates in as both holes have left over plastic screws. Is there any easy way to remove stuck plastic screws ?
Idea/help would be appreciated. Thx
Old Apr 9, 2004 | 07:41 PM
steviej's Avatar
steviej
use a small "easy out",
or
heat the tip of a small screw driver so that you can melt a slot in the plastic that is left in the hole.
Let the slot reharden and then gently ease the remains out of the hole with the same screwdriver.
steviej
Old Apr 9, 2004 | 08:33 PM
lxs300's Avatar
lxs300
Thx steve, thats what in my mind ( heat and remove with sharp screw driver).
Old Apr 10, 2004 | 08:17 PM
lxs300's Avatar
lxs300
That didn't work as those screws that were struck are fibre ones not plastic ones, needs lot hig temperatyure than i thought. Any other idea ??
Old Apr 11, 2004 | 05:44 PM
steviej's Avatar
steviej
back them out with an "easy out" just like you would a metal screw that has broken off.
Sears makes a product for this exact call.
you could try drilling them out with a drill smaller than the inside diameter of the threads, but then you have the thread material to remove.
steviej
ronnieray
Feb 14, 2019 08:40 PM
amaterasu
Aug 2, 2017 07:51 AM
Blade223
Jan 21, 2017 03:08 PM
e-man
Jun 18, 2014 05:56 AM
Juan C. Cos
Dec 22, 2001 12:07 PM
