Alerts found while browsin
Old Dec 7, 2003 | 07:45 PM
playboy13's Avatar
playboy13
Default Alerts found while browsin
Just incase anyone is interested, found this while searching for a solution to my seat heating problem.
if any one can shed somelight on the situation - it would be appreciated, seems like now both of my seats have died.
Buyer's Alerts
1997 - 2001 Lexus ES300
a revised suspension support was designed to eliminate front suspension noise on washboard-type surfaces (SU002-99, Dec. '99);
new brake pads were designed to eliminate groaning, grinding, squeaking or vibrating conditions of the original equipment (BR001-99, March '99);
a "popping" noise from the rear, especially when turning left or right at low speeds may trace to the "V-Brace" weld nut and bolt torque (BO005-97, July '97);
cross connected electrical connectors for the seat heater will result in seat heaters not operating (EL001-97, June '97);
a rattle noise from the moon roof sliding rail assembly may be evident (BO004-97, May '97).
(Service bulletin information courtesy of Alldata Corp)
© 1999-2003, CanadianDriver Communications Inc., all rights reserved
http://www.canadiandriver.com/articl...-01es300_a.htm
Old Dec 8, 2003 | 05:48 AM
lexusk8's Avatar
lexusk8
For your situation, this should be proof enough that the seat heaters in your '97 ES are inoperative. If you bring this list with the "seat heater" item highlighted in front of a service advisor at a Lexus dealership, you can probably get the seat heaters repaired or replaced at minimal or no charge.
RudeDoggy
May 22, 2016 12:37 PM
I8ABMR
IS F (2008-2014)
Jan 14, 2015 09:34 AM
man8959
GX - 1st Gen (2003-2009)
14
Feb 9, 2009 06:54 AM
nissanguy8
Jul 12, 2007 10:22 AM
ISbb
Mar 17, 2007 05:14 PM
