Replacing front door speakers
Replaced right front door speaker six months ago successfully with a used one from eBay that looks like this if the picture is correct (I didn't double-check when I received it and installed it but it works fine):
Now I have one on order from eBay for the left front door that looks like this. That's not the same look. Are they the same (or "essentially" the same)?
And then there's this question: Any advice on where to get decent replacement speakers for the front doors at a decent price? Dealer gets about $220 each.
Any chance there's cross-compatibility with any other Lexus models that open my options for finding good used speakers on eBay for the 2010 ES-350?
(For Mark Levinsons, on eBay I can only find used Mark Levinson speakers for an LS, none for my 2010 ES-350.)
Thanks!
>> Front door speakers (6x9, 7.9 ohms*) : 86160-0W560
https://www.ebay.com/itm/16730750587...Bk9SR8iBrO6nZQ
sunglassguy used these in the front:
I replaced the front speaker on mine with some Sony's. be careful which front aftermarket speaker you purchase because some don't fit into the door bracket properly.
His alpine and my sony did- i purchased some kenwoods that i had to return because the bracket did not fit
It is a long thread and I did not have any idea what part of it you were referring to when you said you did "this." I didn't have any idea which "this" you were referring to in all that. Not complaining, just communicating that I wasn't clear on what exactly it was that you were pointing me to.
The explanation I was then given made it all make sense and I followed through and am following through -- thanks to your initial help! So "Thank you!" again! (And please don't assume negativity when it's not clear what someone's intention is. Written communication is easy to misread.)
https://www.amazon.com/Alpine-R-S69-.../dp/B07ND4SJS6
The link to the ML on eBay (sold out) says they're for up through 2009. Same here: GENUINE LEXUS ES350 RX350 RX400h GX470 FRONT MARK LEVINSON SPEAKER 86160-0W560
I have a 2010 ES350.
Are we reasonably confident the Alpines sunglassguy got per the link above will work in the 2010 ES350?
Can I be reasonably confident that when I find used speakers on eBay that say the part number is 86160-0W560 OEM it will fit my car? (https://www.ebay.com/itm/335854988804, https://www.ebay.com/itm/145902446923, https://www.ebay.com/itm/196894236613)
Or this new one? https://www.ebay.com/itm/204773026884
Or this new one? https://www.lexuspartsnow.com/parts/...160-0w560.html
And are Mark Levinson the standard speakers that come with the car, or a third-party upgrade?
Thanks!
Dealer parts dept quoted X amount and when I called to buy it two hours later a different person was there with a 25% different price, which I assume meant a different part -- even though both had looked up my car from the history and had the VIN in front of them.) I'm starting to think the buzzing sound from the driver speaker isn't all that intolerable after all (just kidding but quite a time-consuming undertaking so far).
Gave up on anything used because of all the difficulty just determining what would be the right fit, returning two purchases I made on eBay that are not going to fit, and even after deciding to "save money by stopping the hemorrhaging of lost time" the battle rages on to find the "right" part from a dealer or major Lexus OEM parts sellers. Real fun.
This seems to be the most reliable source I've found so far for confirming what will fit:
Thanks!
