'09 ES Suspension Problems?
Old Oct 22, 2024 | 09:06 PM
Emmo's Avatar
Emmo
3rd Gear
Default '09 ES Suspension Problems?
Need some help troubleshooting a noise in my ES. Single owner, 85,000 miles, well cared for. I've been hearing an intermittent creak/squeak recently. From the rear, seemingly on the driver's side. It seemed to start after hitting a speed bump harder than expected (I guess with all the SUVs in the world, a local grocery store decided they had to jack them up a few inches, which I discovered when I drove over one at a blistering 5mph and felt a nasty crunch)
What has me puzzled is that I'm not really hearing the noise over bumps, it's more as the weight shifts fore/aft, during acceleration and deceleration. If I push down on the fender I can hear it, but not really driving over uneven surfaces. I'm not seeing anything obvious looking under the car, though there is some corrosion; one of the heat shields over the muffler had to be removed earlier this year because galvanic corrosion had eaten through one of the mounting points.
Wondering if I need to look at new suspension of bearings?
Old Oct 23, 2024 | 09:44 AM
June1978's Avatar
June1978
If you are bouncing the car by hand and hear creaking noises, it's probably the strut
Old Oct 24, 2024 | 06:20 AM
Clutchless's Avatar
Clutchless
It could be the rear trailing arms or control arms bushings. You may need to put it on a lift to thoroughly inspect them. There are other suspension components that could be the source, but it needs a thorough inspection by a professional or very experienced shade tree mechanic.
https://www.rockauto.com/en/catalog/...trol+arm,10401
2wheels
Mar 12, 2023 02:25 PM
Jimindad
ES - 7th Gen (2019-2025)
Dec 2, 2020 06:26 AM
SultanES35
Mar 20, 2019 03:12 AM
350Lexus
Oct 31, 2011 12:04 PM
2000ES300
15
Feb 4, 2007 09:44 PM
