Max tire width stock 16 wheel
Old Sep 7, 2024 | 09:34 AM
Namretsam's Avatar
Namretsam
1st Gear
Default Max tire width stock 16 wheel
Has anyone ran 225 55 16s on es330 ? Wanted a little wider and lower profile tire …
Old Sep 7, 2024 | 12:51 PM
Oro's Avatar
Oro
They will fit, but they will not look lower or have a lower sidewall. The sidewall height is a proportional measurement in %, not absolute. So the “profile” from 10’ away of a 215/60 vs 225/55 on a 16” wheel will be the same or pretty close, just a few mm difference. The car is not so powerful it requires a 225 width tire, either (apples to apples, so to speak - same adhesion characteristics). I would not swap good 215 tires out to do this, but if you were buying new tires to replace worn ones, it would do no harm other than a tiny bit to mileage and odo/speedo error.
If you want the look, get the 17” wheels and use 215/55-17. The ES330 had that option, and any 7 x 17, ~45mm offset Toyota or lexus wheel will fit.
jimisbell
Dec 10, 2021 05:14 PM
72gs455
Feb 13, 2020 09:46 AM
acitydwelr
RX - 3rd Gen (2010-2015)
14
Mar 11, 2019 07:23 AM
mobilyte
Wheels, Tires & Brakes Forum
Oct 12, 2006 12:05 PM
meZoom!
Sep 25, 2002 09:06 PM
