06es330
While driving battery is not charging I can only drive as long as the charge will hold depending on what is in use. How ever when I charge battery off the car it holds charge till ran down. Alternator has magnetic pull when car is running and u hold screw driver in front of it! Also car stays running when I take neg battery cable Off! What gives battery is only a year old! Also when driving after I kill car to run n store or whatever I have to jump it off 7times out of 10 but it fires right up and runs fine!
Appears your alternator is working, would be better to monitor voltage as you drive. Next step is get the battery load tested doesn't matter the age you need to confirm the battery is healthy.
ESHeisler
Sep 16, 2013 07:12 AM
