Oil change interval
Old Aug 29, 2023 | 03:53 AM
FromFL's Avatar
FromFL
Default Oil change interval
I checked my records and I see that the oil and filter were changed on 1/22, and total mileage of 1,270 (miles) driven since then. I know that the Youtube stars bleat 5,000, 6 months whichever comes first (Scotty Kilmer, Car Care Nut). Conversely, the oil forums out there pretty much endorse long oil change intervals (5,000 + miles).
Oil used was Quaker State 5W-30, synthetic, and a Walmart "OEM" filter. Car is never short tripped and sees no winter, so moisture should be of no concern. I do have the oil and filter on deck already bc I thought it was due, but it seems that the old oil on the stick is as clean as when I poured it in...change it, or don't waste new oil? It's an '04.
Old Aug 29, 2023 | 06:15 AM
BillUK's Avatar
BillUK
You are likely to get conflicting views, but personally I change oil annually or 10k, as specified, and use full synthetic.
People like Car Care Nut are possibly correct in that shorter intervals are a little better for engines. That said, in the UK (and Europe) 10k/1 year intervals have pretty much been the norm for most cars for as long as I can remember. As far as I can tell, this hasn't resulted in engines failing for lack of an oil change, any more than anywhere else. In my experience, a car is more likely to be killed by rust, accident damage, transmission failure etc, long before a modern engine, using good quality synthetic oils, fails due to 10k/1 year oil changes.
That's just my opinion (assuming normal driving conditions), which I'm sure many will disagree with, but personally I stick to 10k/1 yr oil changes, make sure that transmission fluid is changed every 60-70k or so, rust proof the underside, cavities and wheels wells and top that up annually, and figure that all will be well short of bad luck.
BMGS
Jan 7, 2021 07:33 PM
LXurious
Jun 18, 2018 08:36 AM
05RX330AWD
Jun 19, 2017 05:10 PM
Gx470blk
GX - 1st Gen (2003-2009)
15
Oct 3, 2013 08:27 AM
vp911
RX - 1st Gen (1999-2003)
Oct 24, 2005 01:55 PM
