Coil Pack
Even Denso prices were all over the place, saw one store had 6 Denso coil packs at $433.00
Not doing that? I refused to buy from ebay also. You hard to get refunded and too long. Sellers are jerks a lot also!
Amazon links are bogus and not showing correct product!
Anybody here know where I can get a set of Denso or NGK coil packs not too expensive? I read here that I may only need rear coils. My cars is running fine except terrible gas mileage! Only getting 9.8 mpg city driving, supposed to get 21 mpg
If I am not mistaken yours has 200000 miles?
I would replace the rear three and keep the old ones as backup should the front go bad. The fronts are super easy to replace; I would replace those as they go bad.
I wouldn't buy anything new off Ebay unless it was from a Toyota/Lexus dealer. The chance of getting counterfeit is too high, even when buying non-OEM, Denso coils. Many Chinese manufacturers are counterfeiting these days. They sell parts that people are willing to pay a premium for in order to get good quality, and charge slightly less for parts that are rot-gut quality at best!
Fuel trims? What is that? How would I check for vacuum leaks? My cars is not showing any Dash icons except low tire indicator as always!
So I bought 6 spark plugs for nothing? I read after I bought them I need to buy gaskets? They mentioned throttle body gasket for one.
I had alternator checked & battery checked today while at parts store, both checked out fine. I had traction control icon and VSC warning lights come on out of the blue after starting car and when I drove it the traction control was engaged! I have no idea how or why that happened! Got it home and parked it, few hours later started it up with no issues and none so far! Very strange!
Since it has 159000 miles I bet they are the factory ones. I don't think anybody replaced them in the meantime.
The fuel trims and the leak you should check with the diagnostic tool, Carista, Techstream, Torque...
It is recommended to buy the gaskets but you don't need if they're not hard to touch.
VSC light can come up because of many reasons, not only related to the system itself.
No, but they are very hard to replace if one of them goes bad later.
