99 ES300 Crank sleeve help
2nd gear
On my '99 ES300 I keep replacing the crank seal-(twice this year)-I have been told the crank may be scored-Is there a sleeve available for the front of the cam that would fix this? Thanks to anyone who knows the answer!
I don't think a repair sleeve for the front crank seal exists. Could try this seal it is thicker than normal which means the seal will contact a different part of the crank. Depends how damaged the crank is of course
https://www.rockauto.com/en/moreinfo...t=5604&jsn=385
BTW you mention crank but then cam, which one do you need?
2nd gear
lumpy85
08-06-10 04:36 PM
