Window not going down
Old May 5, 2021 | 04:30 PM
June1978's Avatar
June1978
Default Window not going down
2002 ES300
Passenger side rear window does not go down using the switch on the door or the switch on the drivers side main panel. I hear clicking when trying to bring the window down from the main panel but nothing from the actual switch on the door itself
Bad motor?
Old May 5, 2021 | 05:37 PM
Arsenii's Avatar
Arsenii
Hello,
It is a common problem on those cars. Before trying to get any parts, slam the door shut a couple of times while holding the switch down, see if it will help. Here is a post that should help you if the previous method didn't work for you.
You can also try an Advanced Search function of this forum, it is usually much more convenient.
Hope this helps and best of luck!
Old May 5, 2021 | 05:42 PM
June1978's Avatar
June1978
Originally Posted by Arsenii
Hello,
It is a common problem on those cars. Before trying to get any parts, slam the door shut a couple of times while holding the switch down. Here is a post that should help you if the previous method didn't work for you.
Just went outside and tried this and it WORKED! ....what in the hell? lol
I turned on the car, jumped in the back seat, held the switch down and shut the door once- switch started to work lol
thanks arsenii !
Old May 5, 2021 | 09:15 PM
Arsenii's Avatar
Arsenii
thanks arsenii !
Well, glad that helped!
There was a TSB (#EL010-06 SEP 06) released for this issue in 2006. From my understanding, the issue lies in the window seal, which, apparently, is somehow trapping the glass in the closed position. Toyota added what they called a "cushion kit" into those seals as a remedy (refer to the picture below), some say it actually worked, some say once the warranty expired, issue persisted.
timkoss
Mar 5, 2021 02:16 PM
AlRose
Jan 28, 2019 07:38 AM
turtle54
Jul 25, 2013 02:30 PM
enio45
RX - 1st Gen (1999-2003)
Jul 25, 2011 08:26 AM
pwesseler
Dec 11, 2008 12:35 PM
