Mechanic stripped engine cradle bolt
Old Mar 18, 2021 | 08:14 AM
CptEs300's Avatar
CptEs300
Default Mechanic stripped engine cradle bolt
So I recently had my control arms changed by a shade tree mechanic and they stripped my engine cradle bolt on reassembly and didn't tell me (I had to find out from another mechanic when I went to get an alignment). I've been looking for a replacement bolt for 3 days and today I finally found one, but no ship that over been too so far knows how to fix the problem or just don't have the right tools.
Does anybody know where I can get the bolt extracted, hole rethreaded or possibly widened and threaded for a larger bolt? What's my best option?
PS: The bolt is just spinning inside the frame, so it's not a rounded head, but stripped threads on either the bolt or the hole
Old Mar 18, 2021 | 09:21 AM
Which one is it exactly? Use this site to find the appropriate diagram.
http://www.japan-parts.eu/
Sounds like the captive nut has broken away from the body of the car if so then there are several solutions depending on the location, one is to cut a hold in the body.
Old Mar 18, 2021 | 09:34 AM
CptEs300's Avatar
CptEs300
It's the 14037 bolt
Old Mar 18, 2021 | 09:44 AM
Does that bolt go through a bracket, through the sub frame then into the unibody? If I have that correct your mechanic is going to need to get creative.
Old Mar 18, 2021 | 10:11 AM
CptEs300's Avatar
CptEs300
It goes through a brace (which connects the lower control arm to the engine braces), through a bushing, then the engine cradle and after that I think it goes into another brace/mount.
I've found a place that has the bolt in stock but it's the game of getting the old one out and rethreading the hole that I'm confused on.
Old Mar 18, 2021 | 11:23 AM
Are you doing this or a mechanic? If there is indeed a captive nut that is turning this means you can't cut new threads. I've done repairs like this before I cut a hold in the unibody, torched the broken bolt and captive nut then had the nut welded in place.
Jas2015
Apr 2, 2026 07:14 PM
Dyslexi
RX - 1st Gen (1999-2003)
12
Apr 1, 2020 10:27 AM
AuntPearl
Dec 14, 2017 07:23 PM
Matt300ZXT
Oct 16, 2010 02:03 PM
milellie11
Jan 2, 2009 09:18 PM
