My New 2001 Lexus ES300 Coach Edition
The rear suspension squeak could be from rusty joints on the sway bar links. I had that noise and couldn’t figure it out for a long time.
Here is how I confirmed it. Bounced the car up and down by opening the trunk and pushing on the frame of the trunk opening up and down.
Then disconnected the rear sway bar links and repeated the process.
Otherwise you could drive it up on ramps and have somebody perform the shake down while you check for noise underneath.
I read about the rear bushings squeaking but it wasn’t the issue with mine. Mine sounded like a spring mattress.
HotRodRod (11-25-20)
Beautiful looking ES! I have a 2000 Platinum Series that I bought 10 years ago with 108,000 miles. Currently at 230,000, and it’s been a fantastic daily driver. Just now changed the Alternator. Like others said, just do a couple drain and fills on the transmission and don’t go over 5000 miles on engine oil changes and you should be golden.
HotRodRod (12-05-20)
I would do it after 15,000 miles then do it again after another 15K. After that you could double the interval if you use a fully synthetic fluid. AFAIK Toyota T-IV aka Mobil 3309 is a full synthetic. I run Amsoil OE Multi Synthetic (red top) car loves it. A member here tried Amsoil Signature Series and had issues, only a sample of one but FYI.
