Windows won’t roll down
Old Jul 8, 2020 | 03:54 AM
Celia92k's Avatar
Celia92k
Default Windows won’t roll down
I have be researching for several days the reset windows thing is not working . My alternator went in my Lexus 2004 Es330 after it got replaced (sat for 4 mths prior ) my Drivers side front window and passenger side front window won’t roll down . Back two will no problem from doors and master switch . I can’t get the front two to roll down no matter what even if I’m at the door . The switch blinks and on the passenger side I hear a small click noise when you try to roll it down . I replaced the master switch in hopes that was the problem but no such luck . Any ideas ?
Old Jul 8, 2020 | 12:10 PM
mcomer's Avatar
mcomer
Key in the driver's door lock cylinder, turn clock wise. Normally that will roll down all window/open sunroof.
Old Jul 8, 2020 | 01:14 PM
Celia92k's Avatar
Celia92k
I tried that with the button and it didn’t roll those down still but illl try this way when I get home tonight thanks
Old Jul 11, 2020 | 06:22 AM
Celia92k's Avatar
Celia92k
no such luck only back windows and sunroof rolled down
Old Jul 12, 2020 | 08:05 AM
VicSWFL's Avatar
VicSWFL
Greetings:
Many ES owners have had the same problem. In the 5 years that I've owned my 2003 ES300, it's happened to me at least 10 times. The answer is a little strange but works perfectly. Turn the ignition on to where the window motors can work. Sit in the seat next to the non-working window. Hold the switch in the position to lower the window and slam the door a few times. This has worked for me every time.
Good luck,
Vic
Fort Myers, Florida
2003 ES300 w/148k miles
Old Jul 19, 2020 | 09:55 PM
gjanz's Avatar
gjanz
Originally Posted by VicSWFL
Greetings:
Good luck,
Vic
Fort Myers, Florida
+1
This method worked for me when my back window was stuck last year. I've also found recently that my driver side window stops working when it's high heat and humidity. After it cools down, it seems to work fine.
Old Jul 20, 2020 | 06:28 AM
Collegeman's Avatar
Collegeman
Greetings:
Good luck,
Vic
Fort Myers, Florida
+2
I did this for my back passenger door and it worked perfectly. I then added WD-40 Water Resistant Silicone to the edges of all the windows so that they would move smoothly without any resistance and its worked great ever since. (Scotty Kilmer has a video on this that I would strongly suggest)
funcrusher
Jul 25, 2019 06:44 AM
justin1203
Apr 26, 2019 03:06 PM
mpatton
Aug 16, 2016 08:07 AM
jpvarghese
Dec 18, 2006 10:26 AM
