Bank 2 Camshaft Position Sensor Bolt size? 2003 ES-300
Old 05-17-19, 07:18 PM
CyFan4036
CyFan4036's Avatar
Default Bank 2 Camshaft Position Sensor Bolt size? 2003 ES-300
I was replacing the bank 2 Camshaft position sensor and dropped the bolt. The engine bay apparently ate it so now I’m stuck. Anyone know what the specs are for this small bolt so that I can find a replacement tomorrow morning? My Lexus dealer’s parts department is closed on the weekends. Any help is greatly appreciated!
Old 05-17-19, 07:26 PM
Received 2,712 Likes on 2,297 Posts
Making a bit of a guess bolt probably looks like this
M6x1.0mm not sure of length.
Old 05-17-19, 07:35 PM
CyFan4036
CyFan4036's Avatar
That’s it! Thanks a ton! I’ll estimate length based on what I saw taking the old one out. Do you know if there is any possibility of damaging anything if it’s a tad long? Thanks again @Lexus2000 !
Old 05-17-19, 07:41 PM
I have a similar bolt if not identical length is 16mm (threads only) this bolt won't take more than 10 lb-ft (spec is probably half that) if the bolt is too long bad things can happen like snapping the head off or the sensor rattling around.
CyFan4036 (05-17-19)
Tonyy
05-16-13 08:50 AM
Matt300ZXT
Performance & Maintenance
10-16-10 02:03 PM
bLingIn3o0
02-17-04 01:16 PM
Quick Reply: Bank 2 Camshaft Position Sensor Bolt size? 2003 ES-300
