02 es 300 idle too high
I have a 2002 es just had 3 coil on plug boot, new plugs, plenum gasket , ignition coil 3, and bg fuel induction chemical kit, I did not do the work on the car, idle is high around 1500 rpm , car runs great, I also have a 04 es and a 08 rx 350, both idle around 500 ,600 after warmed up
only drove the car around 120 150 miles city driving , should I drive it more to re learn how a drive or reduce the idle speed? Is this something I can do? or take it back and the tech to do this , thanks for any info on this
You can rest your idle. Every time I work on my car I have to do this (battery unhooked), I personally find it annoying but it works. If it's still high I'm sure someone else can chime in.
just did what you said on the video, worked great, easy fix car runs great, thanks much better then going to the dealer or back to the shop that did work thanks and have a great day!
jeffreysw
14
01-06-17 06:07 AM
