91 es250 engine cuts out under throttle
Old 04-13-18, 08:02 AM
ES250OG
ES250OG's Avatar
Default 91 es250 engine cuts out under throttle
I have a 1991 es250 5 speed with a 2.5 L V6. When I'm in neutral or with the clutch engaged I can rev the engine Full Throttle half throttle doesn't matter and it's fine. However when I'm in gear and I start to release the clutch anything over about 1,500 to 2000 RPMs the power just cuts out sometimes the car will stall, but it starts right back up. This doesn't happen all the time, and temperature seems to have no effect it happens cold or warm. I know these issues can be a nightmare everyone replacing injectors mass air flow sensors Etc. I think I'm going to start with replacing the ECU but I wanted to see if anyone out there might have a better idea?
Old 04-13-18, 09:45 AM
Received 2,713 Likes on 2,298 Posts
How many miles? Maintenance history?
Old 04-13-18, 11:06 AM
ES250OG
ES250OG's Avatar
just about to roll into 117,xxx miles and I'm the second owner the previous owner didnt say much about the maintenance but having met the guy and judging from how well taken care of the car is, i assume it was well maintained. It was a sunday car for the family and garage kept.
Old 04-13-18, 11:22 AM
That's a tough one. I have two cars with the 2VZ-FE engine (one is a 5-speed) I've never had anything like that happen. The only real problem I had was the intake snorkel was cracked so sometimes I would hear a whistling noise on a cold start and it would sometimes cause hesitation. Some things of note:
Your car does not have a MAF it uses a electromechanical airflow meter. They don't normally go bad. Do NOT remove the screws on the connector, it is held on by a metal clip.
A bad TPS can cause inconsistent engine performance but I've never seen one cause stalling.
A bad EFI temp sensor will cause poor engine running but it usually triggers the CEL.
Poor connection to the battery can cause stalling and similar symptoms to what you describe.
Maybe a bad fuel filter?
If you can find a replacement ECU for a good price that's a good way to rule out the ECU. Assuming your car does not have California emissions there are two ECU part numbers, the first changes up to the 2nd so they should be compatible.
89661-32560 11/1989 - 09/1990)
89661-32561(10/1990 - 06/1991)
Old 04-13-18, 12:44 PM
ES250OG
ES250OG's Avatar
Ok thanks for that. The reason i suspected possibly the ecu is because even before it started doing this was, is, running a rich fuel mixture.
Old 04-13-18, 01:09 PM
Not a bad idea to replace the O2 sensor (Denso 2344051) at the same time. By the time a bad O2 throws a code the sensor is way way past working properly.
Old 04-13-18, 02:02 PM
ES250OG
ES250OG's Avatar
come to think the car does have an exhaust leak either at the manifold or downpipe I'm not sure but it's definitely pre-cat. Could this cause these issues?
Old 04-13-18, 02:37 PM
An engine will never run properly with a leaky exhaust especially if the leak is near the o2 sensor. Not sure it could cause the engine to stall though.
Old 04-13-18, 02:58 PM
ES250OG
ES250OG's Avatar
Im going to park it and over the next few weeks give it a full tune up + some and we'll see what happens. I'll update regularly after each replacement see if i can pinpoint the issue.
Old 05-01-18, 04:04 PM
ES250OG
ES250OG's Avatar
Default Update:
So i replaced the fuel filter threw some seafoam in the tank along with some new gas. Runs strong now.
LeX2K (05-01-18)
Old 05-01-18, 04:41 PM
Good to hear.
Moarpower
03-31-18 09:12 PM
Jbthompson
04-27-15 08:50 PM
davids75
Performance & Maintenance
06-23-14 02:19 PM
sherwoodjb
01-26-11 07:43 PM
Quick Reply: 91 es250 engine cuts out under throttle
