Strut Bar for 1999 ES300
Does anyone know where I can find a Strut Bar for the 99 ES300? My cousin thinks there might not be one because of the little amount of space between the engine and the hood. It be nice to have one for better turning/corners but if you can't get one, is there an alternative?
In my research I've found if you buy one for a 99-03 Solara it will fit. The only product I could find a that actually specified to fit an ES 300 was this one
http://throwdownperformance.com/ultr...i-2119760.aspx
Its a bit pricey though.
There are cheaper ones on eBay. You can use their fitment information to find one that will hopefully fit on eBay if you want a cheaper one.
offremike (04-17-17)
Needless to say, my Solara came stock with the strut bar, so if it does fit, you can source one from the junkyards easily.
Hmm, is it? I remember reading that hood clearance was the reason you couldn't fit a TRD Supercharger on the Camry / ES300 but you could in the Solara.
The junkyard Solara does sound like a good option. I'll probably look into that if my local junkyard has one.
I can confirm a 2000 solara strut bar fits perfect onto a 98 es300. Only problem is closing the hood you have to be gentle it does rub against the firewall padding other than that I see no bump on my hood when it's closed.
I finally had the time today to try this. I pulled one off a 01 solara for my 99 and it raised my hood a little less than 1/4 inch. There is definitely room between the plenum and the strut bar. So it is possible to have a strut bar without raising the hood. Just not the one I got apparently. Maybe I was just unlucky
The solara strut bar fits with some modification. There were 3 places were the strut bar contacted the skeleton of the hood so i took a hammer and pounded it to sit more flat. Not the smartest idea but i just wanted to have a strut bar for scene points so i did it. I missed once, hitting the wrong part of my hood which left a dent
Regardless, i've ran this strut bar for over a year, and i constantly open my hood and slam it shut. I've ran into no problems with the strut bar
(old pic)
(old pic)
(old pic)
Attachment 408818
(old pic)
Attachment 408818
