'95 Lexus ES300 recommended rack & pinion work
Old 04-12-16, 10:43 AM
DRACO A5OG
DRACO A5OG's Avatar
Oh no.
If outer boot is torn, the tie rod would need replacing. Prior to swapping measure the distance and put back in the same spot so you will not be too off on the alignment.
The inner, if the boot is torn just replace the boot but it may require you remove the tie rod end to slip the boot on without tearing it. But before that make sure the gland nut is torqued.
Again, you need to inspect first then take the need steps. We are just guessing now.
Old 04-12-16, 03:53 PM
JCC511
JCC511's Avatar
Originally Posted by DRACO A5OG
Oh no.
I will have to see when I can get it jacked up and have a look. I really appreciate the advice. I have a feeling I will have to replace the inner and outer.
OMAHA
05-14-16 06:37 PM
Eddieguy
01-31-16 01:31 AM
milellie11
09-16-11 06:46 PM
scfocus
Suspension and Brakes
12-06-09 11:13 PM
andyroo
Maintenance
08-14-07 12:31 PM
Quick Reply: '95 Lexus ES300 recommended rack & pinion work
