Tokico struts
Old 01-20-03, 02:19 AM
Ghetto-Pimp
Ghetto-Pimp's Avatar
Default Tokico struts
hey does the Tokico struts lower the car by 1 inch
Old 01-20-03, 02:34 AM
meZoom!
Super Moderator
meZoom!'s Avatar
no, if anything, they should raise your car a bit if you are currently running on very old and worn out struts. get LOWERING SPRINGS if you want to lower your car an inch, not LOWERING STRUTS.
Old 01-20-03, 02:34 PM
Kyle Harty
Kyle Harty's Avatar
Yeah, the struts won't lower the car, and new struts may raise it a little like mezoom said, especially the rear which seems to usually be a little more prone to sagging.
I've got the Tokico's on mine, I've been happy with them. If I remember correctly, you've got Eibach springs, the struts would complete the handling package, the ride will probably be firmer, but more controlled. Even if your stock struts are in good shape now, they won't last that long with the added stress of a lowered car, aftermarket struts would be a good idea ASAP. The KYB's are another option, McElligot has the Eibach/KYB combo and he really likes it.
Old 01-21-03, 03:14 AM
Ghetto-Pimp
yea i have the lowering springs already, so after i get new struts my car's gonna get lifted,
are the Tokico's struts better or KYB
Which one cost more,
and also you guyz know where i could get a camber kit,
for the Alignment
i found one made by eibach for 27 for the back and another 27 for the front, is that a good deal.
Old 02-02-03, 12:39 AM
Kyle Harty
Kyle Harty's Avatar
Yeah, it may be lifted a little, but I wouldn't think it'd be significant unless your struts are real worn out right now.
I don't know if the Tokico's or KYB's are better, haven't used the KYB's or seen enough experiences to say.
Now, the point of this post; I bought the Eibach camber kits and the shop that did my alignment said the bolt didn't fit where it needed to, so they couldn't use the kit. They got the camber within specs without them, but I wasted about $50 on the camber kits; I don't know if mine were a fluke, the parts got mismarked at the factory, or what happened; I can't imagine they all wouldn't fit, but that's just my little warning on the camber kits.
Old 02-05-03, 12:02 AM
skperformance
skperformance's Avatar
actually the rears are almost never needed unless big drop is done
my 18's really need them in front though with the one inch drop
as the inside of the tires edge aren't that great after 2 years while the rest of the tire is 70 % left
wanna sell your fronts?
Old 02-05-03, 10:14 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
Default Re: Tokico struts
Struts don't lower ANY car no matter what anyone says. However, lowering springs do drop the car's ride height.
I recommend the Tokico over KYB simply because the dampening rate is much better. KYB's ride close to stock...the Tokicos are better.
Old 02-09-03, 11:12 PM
Ghetto-Pimp
soo what kind of camber kit should i get
and where can i get it from
Old 02-10-03, 07:59 PM
frankjrsES
frankjrsES's Avatar
i have tokico shocks and eibach springs on my 93 es. im happy with it. the car lowered an inch and the ride is bumpier, but i like the way it feels.
Old 02-10-03, 10:18 PM
Kyle Harty
Kyle Harty's Avatar
Originally posted by frankjrsES
i the ride is bumpier, but i like the way it feels.
That's my overall impression too; the ride's not quite as soft and luxurious, but I think it feels better; handling and stability are much improved; and for me that outweighs the stiffer ride.
I can't imagine all the Eibach camber kits being defective like mine, so that'd probably be a good route to go, I don't know of any other company that makes camber kits for the ES (they may exist, but I don't know of them).
Old 02-11-03, 03:47 PM
flipside909
Lexus Connoisseur
You don't need a camber kit for your macpherson strut suspension. Eibach makes a camber kit for the Camry chassis of lowered suspensions. Tt's not necessary since it doesn't have a cambering problem like double wishbone suspensions do when they're dropped.
Old 02-11-03, 03:49 PM
flipside909
Lexus Connoisseur
That is definitely a trade off of comfort vs. better handling. You really can't have both.
Old 02-11-03, 10:18 PM
Ghetto-Pimp
i ordered a camber kit for 14 for the front another 14 for the back
i didnt get the camber kit made by eibach, but i found another company, lets just hope this one fitz
Old 02-12-03, 04:21 PM
skperformance
what company?
Old 02-12-03, 11:10 PM
Ghetto-Pimp
its made by ingalls
i got it from this site
http://www.mmrusa.com/ingalls.htm
Quick Reply: Tokico struts
