Engine Harness Removal and Connection clips
Old Jun 24, 2012 | 09:59 PM
JSM's Avatar
JSM
Default Engine Harness Removal and Connection clips
So I'm in the process of swaping motors. I was removing the harness from my new motor so i can clean it up.
It seems that every other sensor/injector clip ends up breaking. No mater how carefull I was they just break.
Any one have any simple suggestions before I start removing the one in my car?
Old Jun 25, 2012 | 04:30 PM
GrayES300's Avatar
GrayES300
So far, I have been lucky on my project. Haven't broken any connectors. Bolts, yes, but nothing electrical. Sounds like the plastic is just getting old and brittle. Is it breaking on the tab you push in or when you try to pull the plug? Maybe try spraying with electrical contact cleaner first. Also, try pushing the contact on further while pressing the tab to release some of the tension.
Old Jun 25, 2012 | 07:26 PM
1987's Avatar
1987
Try using a heat gun and warming up the plastic before you unclip it. Dont hold the heat gun too close tho or for too long.
Good luck, plastic connectors are very delicate when they get old...
Old Jun 25, 2012 | 07:40 PM
JSM's Avatar
JSM
I'll try the heat gun. Maybe the harness is better in my car then the motor I got.
No matter if I was gentle, pushed then pulled. The simple press of the tabs would just "snap" and break.
For kicks I called Lexus for a new harness. $1025! Yikes!
jayntee
May 31, 2013 01:21 PM
spitfire7
Jul 12, 2012 08:08 PM
Dai Kaiju
Jul 28, 2011 09:09 PM
