Advice Needed: 2001 ES300 new Motor or Fix
Old 11-09-12, 06:41 PM
  #76
hypervish
hypervish's Avatar
Awesome!
Old 11-09-12, 06:44 PM
  #77
Jeremy-KY
Jeremy-KY's Avatar
Yaaaaaaaaaaaaaaaaayyyyyyyyyyyyy!!!!
Old 11-09-12, 07:42 PM
  #78
RXGS
RXGS's Avatar
i feel happy when i put my own washer fluid, i could only imagine if i did this. Good job and enjoy it, they are great cars
Old 11-09-12, 08:24 PM
  #79
Hayk
Hayk's Avatar
Congratulations! I remember the time I fired up my engine after doing the valve covers, and the satisfaction that it brought to me. You must have felt ecstatic.
Old 11-09-12, 10:52 PM
  #80
MCL23
MCL23's Avatar
I have been following this thread since the very beginning because I love reading build threads. Anyway congratulations!!! that feeling of accomplishment you get when you finish a DIY is priceless.
Old 11-10-12, 03:45 PM
  #81
JSM
JSM's Avatar
Thanks for all the props! I got the hood on today, axles torqued, buttoned up a few loose ends, drained the water out and put toyota red anitfreeze in. $34.00 a gallon! I was shocked.
Well, I was quite happy to have no codes. Unfortuneately, that only lasted about 5 minutes. Both knock sensors are bad. I took the other ones out from my old motor, what a horrible design in my opinion, and zip tied them to the heads. Drove about 10 miles and no more CEL!. Ran the scanner again when I got home and it's clean.
I'm not tackling that job right away.
Only other issue is when the lights are on and I step on the brake, I get this little car with lights like a bulb is out. It goes out after about min and comes back on only when I step on the brakes. Checked all the lights out back and they're good.
Otherwise the car runs great, drives nice. Needs new tires badly.
Old 11-10-12, 03:53 PM
  #82
xspsi6
xspsi6's Avatar
Originally Posted by JSM
Thanks for all the props! I go the hood on today, axles torqued, buttoned up a few loose ends, drained the water out and put toyota red anitfreeze in. $34.00 a gallon! I was shocked.
Did you check the 3rd brake light as well?
Old 11-10-12, 04:34 PM
  #83
JSM
JSM's Avatar
Yep. According to the Owners manual it's some brake light. Guess I'll replace them all and see what happens.
Is there just one bulb in the 3rd brake light?
Old 11-10-12, 04:39 PM
  #84
xspsi6
xspsi6's Avatar
No it's led's so 1 burning out could cause enough resistance change to trip the light.
Old 11-10-12, 04:50 PM
  #85
01LEXPL
01LEXPL's Avatar
Yes it is.
No, they're not.
Old 11-10-12, 06:18 PM
  #86
xspsi6
xspsi6's Avatar
My wifes 00 had Led but I can't speak for other years.
Maybe Canada models differ in this respsct?
Old 11-10-12, 09:04 PM
  #87
Hayk
Hayk's Avatar
Could be a dying bulb, I recommend replacing all of the brake lights.
Old 11-10-12, 09:34 PM
  #88
01LEXPL
01LEXPL's Avatar
USA car I converted mine...
Old 07-29-15, 08:08 AM
  #89
JSM
JSM's Avatar
Well so far she is still running good. Small issues with coolant temp sensor and I need to replace that stupid oil level sensor. It's been my daughters car for the last two years and will move to either me or my wife's car. I bought her a Scion TC. She is so happy! It is a fun little car other than the horrid blind spots.
semlin
02-09-15 03:45 PM
shadowless
04-05-07 05:55 PM
LALEX
12-22-02 12:30 PM
Quick Reply: Advice Needed: 2001 ES300 new Motor or Fix
