ES330 Aftermarket Interior LED
^ Just as described its in a weird angle/tight spot;
https://www.clublexus.com/forums/es3...bs-to-led.html
I changed mine. Use gloves and have patience. You'll have to shift the battery to get at the drivers side bulb.
So are the front map bulbs ba9s? I can’t find any info on them.
I replaced these on my 05 ES330 with these BA9S LED bulbs. They aren't as bright as stock though.
The stock foot-well lighting is very dim. I'd forgo replacing the bulb (since it only comes on at night and when the car is in park, not when the doors open), and add some LED/ CCFL strips.
Here's how I installed them:
http://www.youtube.com/watch?v=WWM8F6q-a5o
Here's how they came out:
http://www.youtube.com/watch?v=Mm5CSI-FOeU
What i use for my front center lights
Other bulb sizes
https://www.superbrightleds.com/vehi...=762&year=2005
https://www.amazon.com/LUYED-Bright-Chipsets-Courtesy-Lights/dp/B018LUUON8/ref=sr_1_fkmrnull_4?keywords=luyed+ba9&qid=1555503888&s=gateway&sr=8-4-fkmrnull
Other bulb sizes
https://www.amazon.com/LUYED-Bright-...r=8-4-fkmrnull
Other bulb sizes
Other bulb sizes
How about you post a picture of the bulb you're trying to replace.
Any pictures? If you send us your stock bulbs we can probably use the housings to make them into LED's if you can't find anything.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
Well I won’t be able to get to my car for a little while but found the part number for the map light bulbs
90981-12020
I called the dealer and they said they’d have to actually order it to verify the bulb type. Mystery bulbs!!
90981-12020
It would be a little different probably but I ordered a kit from JDM toy for LED interior lights map lights door lights and license plate light first $35 for my 2005 Avalon back in the day I haven't looked for Lexus yet...
SilentWish
09-01-10 01:19 PM
