PCV Valve 1MZ-FE
PCV Valve 1MZ-FE
I think its time to change my PCV Valve and grommet. There's some pretty nasty build up and/or over flow around the perimeter of the valve location.
Does the PCV valve screw in/out or slide out?
It really was that simple...
Cleaned the valve area with some engine degreaser that I sprayed on to a rag and used needlenose pliers to pull out the rubber grommet.
Change the PVC everyother oil change (about 20K)...change grommet about every 25-30,000 miles...If it falls in, get the needle nose pliers out. After over 200K miles, been there, done that.
