Should I get an Alignment...
Old Jan 12, 2009 | 02:39 PM
hoonami's Avatar
hoonami
Default Should I get an Alignment...
Today I replaced all 4 tires on 02 ES300. Car drives fine, but old tires had uneven wear which wasn't really that bad but it was uneven. should i still get alignment done to it? i have 110k miles on it now...
thanks,
Tae
Old Jan 12, 2009 | 02:45 PM
herbvdh's Avatar
herbvdh
thanks,
Tae
New tires require an alignment. If you wore the old tires uneven you definitely need an alignment.
Old Jan 12, 2009 | 03:01 PM
hoonami's Avatar
hoonami
is it 4wheel alignment? or just front only?
Old Jan 12, 2009 | 06:52 PM
herbvdh's Avatar
herbvdh
Front wheel drive you align all four wheels if not you will be driving the car on an angle down the road I have scene this a few times already.
Old Jan 12, 2009 | 07:02 PM
92ES5sp's Avatar
92ES5sp
Its a 4 wheel alignment, but toe is the only adjustable angle on your ES 300. If camber is out, check for bent parts like struts or control arms. If camber is only a little out, you can get aftermarket camber adjusting bolts installed. Ask for a printout.
Old Jan 13, 2009 | 06:44 AM
hoonami's Avatar
hoonami
will do... thanks guys... i am taking my car to either sears auto or just tires for alignment. and is there anyway to know if balancing is off on tires?
cherrypik
Jul 13, 2011 08:48 AM
Vpanin
Oct 18, 2010 04:26 AM
MarcusMIA
Oct 14, 2009 07:08 PM
RocketGuy3
Southwest
Aug 26, 2008 10:29 AM
