ES Strut Bar Fits Camry and Solara?
oh so itake it the solara strut bar has the same problems as the trd one where you have to dremel a part of the hood.
How about the ebay ones? the ones that fit a 97-01 camry? I would assume the 4cyl and 6cyl chassis are equivalent, correct?
ok im soo lost in this thread. so wait does the 2000-2001 camry strut bar(front) fit the 1997-2001 es300? im thinkin of getting a 2000-2001 front strut bar...would it fit? whut about the rear sway bar? what cars are compatable for the rear sway bars?
For the strut bar and the rear swaybar you would need to order the parts for a 99-01 solara. The trd strut brace is 94$ and the rear swaybar is 145$ The rear swaybar has two settings, track and street. Mine is set to track. I ordered the swaybar for the 99 solara and it fit without a problem. The car handled sooo much better with it installed.
Guest
Posts: n/a
If ordering a swaybar for a 97-01 es-300 order the swaybar for the 99-01 solara v6. Both front and rear. For a 92-96 es300 order for a 92-96 camry v6. Whiteline sells them. For the strut brace order it from a 99-01 solara v6. heres a link for the strut brace
heres a link for the trd swaybar
These are the cheapest place i've found this stuff and they are 100% reliable. If looking for whiteline products check out www.ctmotorsport.com he can also order a whiteline swaybar that may have been made for an es300. But i'm pretty sure it's going to be the same part # as a camry swaybar. The whitleine swaybar is a little thicker than the trd. but the trd is adjustable. TRD does not make a front swaybar. Some say that having a front swaybar will lessen or cancel the effect of having a larger rear swaybar. Im running only the trd rear swaybar. And don't feel the need for a front one. But then again I haven't tried it with one so...
Also remember to get the energy swaybar bushings with regreasable bushings. Without them they will after time start to squeek.
For the ES/camry's that can have a front sway bar. Leave it off, or stock (However it comes)
Correct TRDMCV20.
The only way you would need more front sway is if you seriously didn't match the rear one. IE put one way to thick & stiff on the back, and now you're oversteering horribly. Just stick to the rear sway bar + tower brace & reape the benifits.
Correct TRDMCV20.
Lexus Connoisseur
Lexus Connoisseur
Fits my Avalon fine.
Found and pulled one off of a Solara in a junk yard and it fits in my 98 Avalon GREAT, just that little stiffness I want to.
It doesn't bend the hood at all but closing the hood it's just a tad tighter.
