Green light would not turn off when key is on. Car crank but would not start. Hook up Autel scanner. It would not connect to the engine function only body function like door lock power window ext. ecm has been check out and fixed by local company supposely
. It’s a 2003 es300. Any help is appreciated before take it to the shop.
Reason: Wrong color
My guess would be bad key fob. Only has one key. All the windows locks work perfectly with the key fob. Try to narrow down the problem. Don’t want throw money into it and hope the best. Can shop check the function of the fob?
FOB has nothing to do with your problem, the engine computer is not getting power assuming no one removed the CEL bulb. About the only time I've seen the ECU not get power is when people hook up jumper cables backward and blow a bunch of fuses.
I pulled all the sensors one at a time. Still the same. No check light on dash. Next check ecm getting power or not. Which pin and the color of wire should I check? Thx for any info.
