stock 2014 Lexus CT200h to VIP car
Hello,
I'm really new to owning my 2014 Lexus CT200H, and I've always grown up around Hondas and only focusing on performance. So this is completely different for me to want to change my daily into a VIP car.
I don't really know anything at all when it comes to cosmetics.
So my questions would be for now are:
1. What are the wheel specs and what should I go with if I plan on bagging the car?
2. For when I do want to bag the car, do I get that done first or should I invest in the wheels first?
3. What best wheel companies would you suggest I check out in the SoCal area?
First off congrats on your CT!
I would first look at other CTs to see different styles and base your idea off them. Next I suggest buying and installing your suspension wether bags or coilovers first. You don't want to buy wheels and then they won't fit after.
I can give you some ball park wheel specs depending on what setup you decide to go with (assuming air suspension):
Slammed and tucked front/back utilizing natural camber only: 18x9 +35-45 215/35/18 and 18x9.5 +25-35 215/35/18.
Flush lip to fender: 19x9.5 +38-45 215/35/19 and 19x9.5 +25-35 215/35/19.
Also check out the modded thread. There are a lot of nice cars there with wheel specs posted.
As for any car shops in your area I'm not sure because I don't live in cali, but Evasive Motorsports is located in cali and they are an authorized dealer for various JDM wheels.
The following 3 users liked this post by squid808:
Hello,
awkFishy (03-31-18)
Thank you @squid808 for pointing out the basics for me on that. That actually helps a lot. I used to follow a few VIP looking CTs on IG, and that's generally what I was basing off of my ideas, but I would search through their posts to see what they did & they generally didn't provide it so that's why I had to post the thread here with as very basic questions possible.
Thank you @oldwineguy ! I followed you on IG the moment I did get my CT & I truly like the way you fixed yours up along with how @fancyprius does his style.
It's my daily & it's my first project, so I plan on going on with it for as long as I possibly can. I'm still a student & freshly moved to CA on my own, so financing is a problem but I'd save up to do whatever I can. But in your response compared to @squid808 , you say to get the wheels first. That's where I guess I'm more confused at. Should I get the wheels first & then get my car lowered/bagged after to fit it in?
I'm guessing it depends on how you want your setup.. these guys done it before so i'm assuming it won't matter. I plan on getting air in a couple of months. With that said, i'd want my wheel setup to be tucked but close to the wheel wheel, so i'd get wider wheels but I won't know by how much until I put bags first. If that makes sense why you would do air first. Running a squared setup (all same tire specs front and rear) close to stock, then you could get wheels first.
-Also, if it were me, i'd invest in the large price items first, that's up to you though.
I have wheels now, but they are basically same as stock, only the offset changed by a couple of numbers. Tire sizes and rim remained the same. Going forward, I'd go with Air first only because I plan on going to 18's with wider wheels on front and rear.
Yeah it seriously depends on the situation. Like if you plan to bang it out mod after mod where money is no issue I would go with suspension first, get it slammed and measure your wheel specs, then order wheels. This way you can get the damn perfect fitment you want with no headache.
If you on a budget and can't bang it out then wheels would be a good choice to start with so you can stand out from the crowd while you save up for the suspension. Or who knows, you might even be satisfied already lol.
Also would recommend getting adjustable lower arms for the rear and camber plates for the front. With these parts you would have a ton of control with fitment.
