CT 200h Model (2011-2017)
Error sign on dashboard
Old Feb 9, 2023 | 09:39 AM
1maz's Avatar
1maz
7th Gear
Default Error sign on dashboard
Hello people I have a lexus ct200h 2013 plate I have a sign coming up on the dashboard saying key detected in vehicle I have changed the battery on the key fob but still comes up when I go over humps please help us out thank you
Old Feb 10, 2023 | 06:42 AM
Lexmex's Avatar
Lexmex
I have had this happen to me, but only thing I do if error does not clear is I take the key fob and touch it to Start button.
Old Feb 10, 2023 | 07:54 AM
morganc's Avatar
morganc
You could try cleaning the battery contacts (both top and bottom) with rubbing alcohol and a q-tip. If that doesn't work, then I'd just live with it..could be a flaky chip on the key fob circuit board.
Old Feb 10, 2023 | 07:39 PM
TobiasSing's Avatar
TobiasSing
The CT comes with 2 key fobs. Do you have this issue with both, or just one?
Old Feb 10, 2023 | 09:35 PM
1maz's Avatar
1maz
7th Gear
I only have one fob
Old Feb 13, 2023 | 07:28 AM
Raidin's Avatar
Raidin
Does this happen while you're driving? It almost sounds like it's detecting another key, or a key is not in range of the start button (you can set the car to only start if the key is in the driver's seat area, or the anywhere inside the car). Normally this warning happens when you try to close and lock the car while the key is still inside.
Old Feb 13, 2023 | 11:37 PM
1maz's Avatar
1maz
7th Gear
Thank you for your reply yes it happens when I go over humps I drove it on Saturday it was OK I will be back to work tomorrow I will see how it goes thank you
Old Feb 13, 2023 | 11:39 PM
1maz's Avatar
1maz
7th Gear
Old Feb 14, 2023 | 08:43 AM
Raidin's Avatar
Raidin
Oh I'm sorry, I missed the part where you said it happens as you go over speed bumps.
This is what the manual says, by the way:
Old Mar 14, 2023 | 06:13 PM
Raidin's Avatar
Raidin
Okay, I think I figured it out. Why? Because the same thing happened to me earlier.
So basically, what happened was my hatch was not properly sealed because I had some cargo that was pushing a bit at the edge. Each time I went over any kind of bump that was strong enough, it unsettled the latch for the rear hatch, and the car thought that the door was open for a moment, but because everything was locked, the car was letting me know that the key is still inside the car.
We all know that we get this message whenever we try to lock the car while the key is inside, so if your car is locked and the car thinks a door was just closed, of course is going to flag this message while you're driving since of course your key is inside with you.
I did discover a fix to use while you're driving when you don't have time to actually go close your hatch or whatever door that might be partially open. Just hit the lock button on your door as you drive and it will get rid of the message each time it comes up.
Ekul61
Feb 25, 2023 11:24 PM
Jordo609
Oct 31, 2011 02:25 PM
cdaggett
May 25, 2009 07:33 AM
