CT 200h Model (2011-2017)
Heater Core?
Old Nov 8, 2022 | 12:49 PM
imayzguy's Avatar
imayzguy
7th Gear
Default Heater Core?
Hi Everyone!
my 2017 CT200h has been leaving a slight cloud on the inside at the bottom of the front windshield for the past couple months. Now I have a slight coolant smell. I’m in denial it’s the heater core. No smell under the hood. Is there anything else or something common to these cars regarding my symptoms? I hear there are two different coolant reservoirs. True?
if this turns out to be the heater core has anyone ever changed their own? Any advice?
Thank You!
Old Nov 14, 2022 | 10:47 AM
morganc's Avatar
morganc
This is sounding like it could be the core. Perhaps stuff the windshield vents with paper towel to see if they eventually turn pink. Yes, there's two coolant reservoirs, but they are not related to each other. The reservoir on the driver's side of the car is the inverter cooling system, and the one on the passenger's side is your engine/hvac loop.
I looked through my manual; in a nutshell, it looks like evacuate the A/C system, remove wiper tray and associated ducts under the hood, remove steering wheel, steering column, disconnect brake pedal from dash assembly, remove all dash pieces from the main dash, remove the main metal lateral dash support, etc etc.
So it's not taking the whole dash out, per se, but it's essentially peeling it all off to get to it.
Originally Posted by imayzguy
Hi Everyone!
Thank You!
doobs
Dec 11, 2021 11:25 AM
Tabaka
Jun 1, 2016 09:53 AM
Session101
Dec 6, 2013 02:48 PM
greens14
Feb 25, 2013 08:30 AM
Lexushead
Mar 8, 2009 07:19 AM
