19x9.5 ET35 fit?
if youre running only fsport lowering springs then more than likely the wheels should fit without any modifications (not going to be flush or anything) and you will have some serious sticking out wheels. possible problems with the 9.5" in the front is rubbing when turning or going over a speedbump. if youre uneasy then take some measurements of your current setup and calculate the differences.
im also running 9.5" all around (+16 rear, +44 front) but i have coilovers and camber equipment and stretched tires (19r/215/35).
This gives you a rough idea of what you'll end up with (assuming your tire size). You can use the tool on the website, rimsntires.com, to make any changes to your diameter, offset, tire size, etc.
nismo4life
18
May 27, 2013 09:27 AM
Ownagespot
Dec 21, 2012 06:46 PM
GSLEX0586
Jan 31, 2012 02:25 PM
