CT 200h Model (2011-2017)
Rear brake caliper replacement bleeding procedure
Old Jun 13, 2026 | 10:13 AM
LazarusLng's Avatar
LazarusLng
Default Rear brake caliper replacement bleeding procedure
Im in the process of replacing the rear calipers. I disconnected the battery before starting. I was researching the brake bleeding process and kept coming across posts and videos that pertain to bleeding the abs module.. Im not coming anywhere near that module with the rear calipers. I had hoped I could simply use a vacuum bleeder at the calipers and that would be that. Hopefully one of you fine folks can set me straight on this. Thanks!
Old Jun 14, 2026 | 01:00 PM
morganc's Avatar
morganc
You have to put the car in Invalid mode (google it) before doing any brake work, or else the hydraulic pump will activate when it senses a pressure drop. Once the caliper work is done and you're still in invalid mode, you can vacuum bleed. Invalid mode prepares the brake system to be worked on and properly bled.
LazarusLng
Nov 23, 2025 09:58 AM
jerkyboy
Jul 26, 2025 10:51 PM
hotwing
Nov 1, 2024 12:22 PM
Sanac
Aug 15, 2024 03:31 PM
LexusHOG
Oct 16, 2021 08:22 AM
