Any SoCal 2IS with navi experience map glitching/faulty position calibration lately?
"menu" button
"setup" icon
scroll down to the third page
"adjust" button next to "calibration"
see pages 92-93 of your Navigation System Owner's Manual for more details.
if it's still glitchy, try updating your nav software to a newer version.
strange though, because i haven't had to calibrate my nav since it was nav-hacked.
"setup" icon
"menu" button
"setup" icon
"setup" icon
i tried calibrating it. it makes no difference. when i was reading the manual it says the GPS should relocate automatically, the only reason i would have to recalibrate is if i'm in an area with poor GPS reception. i'm going to try to reset my battery and see if it makes any difference. by any chance, is the GPS position sensor built into the head unit? or does the sharkfin antenna play any role? i want to avoid going to the dealer and risk voiding my warranty as much as possible. on the same note, does anyone know of a mod-friendly advisor??
exclusive matchup
i am also in fullerton and oc area, never had problem on my nav. shark fin is for xm only, nothing to do with nav. pay attention to the GPS wording that's right below the compass and scale on the top left corner. pay attention when you are driving. do you see the GPS wording all the time?
mooncake master
You should be concerned if maybe one of the wires are loose. Might be giving you a bad connection. Now I can't remember, IIRC even if you have GPS showing all the time, if the wires are loose you will get a jumpy nav due to the Vehicle Speed Sensor (VSS) wire being cut. But it's been so long, I just can't remember. So I can be completely wrong.
