MM Retro-Write-Up: AMC Eagle.....The Original Crossover
Old May 22, 2020 | 07:06 PM
mmarshall's Avatar
Default MM Retro-Write-Up: AMC Eagle.....The Original Crossover
(Sedan)
(SX-4)
IN A NUTSHELL: The original AWD crossover-vehicle, and fifteen years ahead of its time.
AMC (American Motors), as a corporation, tends to be overlooked in automotive history, as, for most of its own history (and in its earlier ties to Nash and Hudson) it was overshadowed by Detroit's Big Three, and, for a time, after Renault ownership, was actually owned by one of the Big Three (Chrysler). However, despite some controversial styling-designs such as the Gremlin, Pacer, and mid-70s Javelin, most of its vehicles drove like appliances, and it was never really able to significantly bite into the Big Three's share of the U.S. market. By the late 1970s, it was foundering badly, and the company decided it had to do something new and radical, to give the public a good reason to visit an AMC showroom.
The project turned out to be the 1980 Eagle, based on the compact Hornet/Concord, and the smaller Eagle SX-4, based on the sub-compact Gremlin/Spirit. The Eagle represented something that had never been attempted before on a production basis...a regular production station-wagon/sedan/hatchback, raised up several inches from its normal suspension-height for added ground clearance, and equipped with a novel car-based All-Wheel-Drive system. This differed radically from earlier, truck/Jeep-based 4WD systems, which had no center differential, went in and out of 4WD with a manually-shifted transfer-case, locked up all four drive wheels up at the same rotation-speed, usable only off-road or on slick surfaces, and, sometimes, required the driver to stop the vehicle, get out, and manually lock or unlock the front hubs to engage/disengage. AMC's new system did away with most of that procedure, with an automatic transfer-case, permanently-locked front hubs, and a center-differential, which used a viscous-type material inside to split the torque between front and rear wheels, which, in conjunction with the front/rear differentials, allowed all four wheels to rotate at different speeds, so the vehicle could go around dry-pavement curves without binding up. Although the Eagles used a traditional fore/aft engine-alignment (AMC in-line sixes hooked to the Chrysler Torque-Flite automatic transmission), the general idea, using transverse-engines, became the cornerstone, some 15 years ahead of its time, for an eventual revolution in the auto industry. Subaru, which, along with Audi, had perfected the concept of car-based AWD after AMC went out of business, expanded upon the Eagle's original idea with its revolutionary 1995 Outback, which went on to enjoy tremendous success, and is still a huge seller today. Indeed, today's entire world of crossover AWD vehicles, which represent a clear majority of the industry today, can ultimately thank AMC for the original concept.
Despite the fact that it was not a huge seller (and, of course, did not prevent AMC from going out of business), the Eagle and SX-4 had several other advantages besides just the concept of the new torque-slitting viscous-coupling. Its higher ground clearance made it easier to go through deep snow, even with AWD, without getting stuck. The ground clearance also made repairs/service under the car easier without using a lift or ramps. The doors were at just the right height for easy entry/exit without having to stoop down or step up on a running-board...a boon for a lot of older people. And ditto for the trunk-loading height...easier loading/unloading.
Unfortunately, perhaps because of the AMC logo (the public, back then, was not particularly enchanted with the company), these cars languished in the sales department, and their true worth was not recognized until well over a decade later. This was not (and is not) the first time in automotive history that something like that had happened, but I felt it was a real shame that these cars, at the time, did not get the credit they deserved. I confess that I myself, to an extent, did not fully-appreciate them myself, since I had, as with most of my classmates in high school, grown up with a questionable view of AMC. One of my friends had a (then-new) 1970 Hornet that his parents had bought him, and, while reasonably well-asssembled, it used ultra-flimsy trim-materials inside, and drove and sounded like a mail truck.
I don't remember a great deal about how the Eagle actually drove, so I certainly couldn't write a review (especially a full-review) about it....but, what little I recall about it is that it was pretty much what one expected.....a run-of-the-mill AMC Concord with a slightly firmer suspension, slightly more body-roll from the higher center of gravity, and, of course, (although I didn't sample it in the snow) a lot better wet/winter-traction than the RWD version.
Do I wish I had actually bought/owned one? Maybe. It certainly would have made winter driving a lot easier, albeit at the expense of some engine power and gas mileage from the weight/drag of the AWD system. And it (probably) would have been a better car than my awful Chevy Citation was, which I bought around the same time....1980. All Eagles also came with standard Ziebart rustproofing and Galvanized steel body panels. But AMC, though not down to Chrysler and GM's level of poor quality control at the factory, was not known for particularly good fit/finish, and their vehicles were not known for long-term durability or longevity. And I wouldn't have wanted to be stuck with a vehicle from a company that was going out of business. So, the Eagle simply remains something for me to write about from memory, and for what it accomplished later on when its true qualities were appreciated.
And, as Always, Happy-Car-Memories.
MM
Old May 23, 2020 | 03:48 PM
Wallie3145's Avatar
Wallie3145
I might be wrong, but the increased height made it more difficult to load in the Eagle as neither the sedan or wagon had bumper level opening.
Old May 23, 2020 | 04:10 PM
mmarshall's Avatar
You might have a point. Depends on the person. I'm taller than average, so the lack of bumper-height didn't make it any more difficult for me.
Old May 23, 2020 | 07:43 PM
LexusFanUS's Avatar
LexusFanUS
I own an LS500 and two AMC Eagles. You might like this video:
and here are my Eagles:
Old May 23, 2020 | 08:23 PM
mmarshall's Avatar
Thanks for posting.....enjoyed watching them. Good luck on your project.
Old May 24, 2020 | 11:19 AM
Big Andy's Avatar
Big Andy
The wagon version looks OK actually, the saloon and hatchback are less successful.
Old May 24, 2020 | 02:54 PM
mmarshall's Avatar
The 5-door wagon version was obviously the most practical and versatile version. It was the same with the Subaru Outback, introduced about 15 years later on the same general theme (raised-suspension, AWD, sedan/wagon platform). The Outback sedan flopped badly, but the wagon was a huge success.
Many are not even aware that an Outback sedan (saloon in British-speak) was ever in production. Subaru called it the SUS (Sport Utility Sedan). Here's a shot.
Old Mar 20, 2021 | 09:28 PM
Felix's Avatar
Felix
When the Eagle first came out back in late '79, I really thought those were cool...btw the first year used the 258 & next yr AMC went w the 4.0.....
Old Mar 21, 2021 | 03:59 AM
mmarshall's Avatar
That car was 15 years ahead of its time....and a Bellweather. By the mid / late 1990s, a large chunk of the auto industry was converting to its format in one way or another.
Old Jan 18, 2022 | 03:14 PM
Och's Avatar
Och
Hey Mike, someone did a rendering of what a 2022 AMC Eagle might have looked like.
MM Retro-Write-Up: AMC Eagle.....The Original Crossover-lbnl5bp.jpg
MM Retro-Write-Up: AMC Eagle.....The Original Crossover-penf1d8.jpg
Old Jan 18, 2022 | 03:45 PM
mmarshall's Avatar
Nice photoshop.
I always liked that side-wood-tone paneling....after the 1940s, with all the trouble/time/effort it took to take care of the REAL wood wagons, the wagon-manufacturers used big stick-on-appliques instead. Also made it a lot easier to repair after an accident.
The Eagle, and the Concord that preceded it, are two products from AMC that I somewhat regret not having owned at the time. My late father was a dyed-in-the-wool Chrysler fan, particularly of the Slant-Six and small V8 engines (perhaps not without reason, as they were among the most durable American-designed engines of all time, even if the rest of the vehicle was not that impressive), and although I was an adult old enough to make my own decisions, he still put a lot of pressure on me to make my first new car (in my own name) a slant-six Plymouth rather than an AMC product.
Old Jan 18, 2022 | 03:48 PM
Och's Avatar
Och
The render looks very Subaruesque.
Old Jan 18, 2022 | 03:52 PM
mmarshall's Avatar
Although the Audi Quattro system also gets a lot of respect and acknowledgement, Subaru probably did more than any other manufacturer to perfect the concept of the original AMC Eagle, and give us one of the most successful AWD wagons of all time...the 1995 Outback. The very name "Outback" itself symbolizes wagon-competence in the snow. I know...I owned one myself for six years (2006-2012)
Old Jan 18, 2022 | 03:59 PM
Och's Avatar
Och
Older, and perhaps even newer, Subarus might very well be the spiritual successors to the AMC wagon.
MM Retro-Write-Up: AMC Eagle.....The Original Crossover-opweeuu.jpg
MM Retro-Write-Up: AMC Eagle.....The Original Crossover-c23wxwr.jpg
Old Jan 18, 2022 | 04:02 PM
Och's Avatar
Och
After further research, turns out Subaru was making AWD wagons before the AMC Eagle. Mike, your title is wrong, the AMC is not the original crossover, this is.
https://en.wikipedia.org/wiki/Subaru_Leone
