2020 Ford Mustang EcoBoost High Performance Package
Old Apr 15, 2019 | 06:36 PM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
Default 2020 Ford Mustang EcoBoost High Performance Package
Focus RS engine goes to the Mustang
The "entry-level" performance Ford Mustang is here, and it's called (deep breath) the 2020 Ford Mustang EcoBoost High Performance Package. While it doesn't have a particularly elegant name, this hopped-up Mustang EcoBoost has some exciting parts, starting with its Focus RS-sourced engine.
And this really is the Focus RS engine, not just a derivative like the regular EcoBoost. It has the stronger cylinder head and head gasket of Ford's outgoing hot hatch, and, just like with the Focus RS, the engine is built at the Valencia, Spain, factory before coming to Flat Rock to go into a Mustang. As for the bits bolted to the engine, there are a few changes in piping and intercooler design due to the new engine arrangement. The turbocharger has been redesigned, too, and is unique to this Mustang variant. The results are 330 horsepower and 350 pound-feet of torque. That is indeed a bit less than the Focus RS, but Ford says that this engine setup will provide a wider powerband with better low- and high-end power and torque. Ford also claims the automatic-equipped version will hit 60 mph in just 4.5 seconds. Since this is a beefier engine, we're hoping the aftermarket will be able to extract even more power out of it than it could with the regular Mustang EcoBoost engine. The engine sounds particularly mean, too, now that the active exhaust is a standard feature.
The new engine is naturally accompanied by other upgrades, many of which match the current Performance Package for the 2019 Mustang EcoBoost. They include the 3.55 ratio limited-slip rear differential, 255-mm performance tires, a shock tower brace, Mustang GT brakes with front four-piston calipers, and unique tuning for the suspension and driver aids such as stability control. The car is also now electronically limited to 155 mph and gets ducting from the Mustang GT to improve brake cooling. There will be a Handling Package that can be added to the High-Performance Package that will bring 265-mm wide tires, magnetic suspension, stiffer springs, and even thicker anti-roll bars.
Visually, the High Performance Package Mustang is subtle but distinct. Up front is the lip spoiler from the GT Performance Package 1 along with unique dark metallic gray grilles with a side-mounted pony badge. The hood gets a pair of stripes that run along the lip of the hood cowl and fade away toward the back. They have the same color as the grilles. There are also unique wheels and the Mustang GT rear spoiler, once again finished in the same color as the grilles and stripes.
The Mustang EcoBoost High Performance Package goes on sale in early fall. Pricing will be coming by the end of spring. The package will be available on all versions of the Mustang EcoBoost from bare-bones base trim to fully loaded, as well as in coupe, convertible, manual and automatic configurations. The only restriction is for the Handling Package upgrade, which is only available on the coupe.
Source
Old Apr 15, 2019 | 08:21 PM
that would make it the Ford MEH Performance Package
Old Apr 15, 2019 | 10:06 PM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
20 more horsepower than the standard EcoBoost, and same 350ft-lbs
Old Apr 16, 2019 | 07:05 AM
mmarshall's Avatar
Even the standard EcoBoost Mustang, without the Hi-Per package, is no slouch. I did a review of one a few years ago, and its performance, with the manual transmission, reminded me of some of the lower-level Mach 1 Mustangs I grew up with....with the 351 (5.7L) and 390 (6.4L) V8s.
Old Apr 16, 2019 | 07:51 AM
bagwell's Avatar
bagwell
Meh still rather have a base GT, leftover 18s are cheap I bet.
Old Apr 16, 2019 | 11:06 AM
mmarshall's Avatar
I understand your point, but, depending on your age and driving record, a GT Mustang, over an Ecoboost, will probably run a lot more in insurance without really that much extra performance. And the way many GTs are driven pretty much explains the insurance surcharge.
Old Apr 16, 2019 | 01:16 PM
ABC's Avatar
ABC
CL Folding 100,000
lol perfect
Hoovey689
May 31, 2019 01:59 PM
