DIY: Door Hinge Replacement
Old Jan 7, 2019 | 04:01 PM
speedkar9's Avatar
speedkar9
Default DIY: Door Hinge Replacement
Here’s how to replace a car door hinge that’s sagging:
When a hinge is worn, the door drops and doesn’t align with the latch or other body panels:
DIY: Door Hinge Replacement-ov6ci4k.jpg
The fender, headlight, bumper and fender liner need to be removed and/or loosened to get access to the hinges. Here the headlight bolts are loosened along the radiator support:
DIY: Door Hinge Replacement-bx4skqr.jpg
The fender liner bolts are removed next:
DIY: Door Hinge Replacement-xlw52yr.jpg
A bolt underneath holds the splash guard:
DIY: Door Hinge Replacement-1uozy0k.jpg
The bumper pulls away from the fender, revealing more bolts that hold the headlight to the fender:
DIY: Door Hinge Replacement-4obksjp.jpg
Three 10mm bolts are removed:
DIY: Door Hinge Replacement-jfxkupg.jpg
One 10mm bolt behind the hood hinge:
DIY: Door Hinge Replacement-xxquuju.jpg
One bolt above the upper door hinge:
DIY: Door Hinge Replacement-cwzmg4b.jpg
One more bolt behind the triangle in front the mirror:
DIY: Door Hinge Replacement-hjqbs8z.jpg
Remove the fender:
DIY: Door Hinge Replacement-vdvgiao.jpg
To save these clips they have to be removed from the inside:
DIY: Door Hinge Replacement-71d3z1e.jpg
Fender removed:
DIY: Door Hinge Replacement-xpu9mtl.jpg
I got used hinges from the junkyard for $8 each from a Toyota Tundra and a Sienna:
DIY: Door Hinge Replacement-b8ydefh.jpg
Hinge bolts are 12 mm. The door bolts here were already loosened:
DIY: Door Hinge Replacement-u1iytvk.jpg
DIY: Door Hinge Replacement-owvyxcc.jpg
Finally the door is tested and the body panels are but together. Things are a lot smoother now without a drooping door!
Enjoy!
LuxuryGS3
Aug 8, 2012 09:28 PM
toy4life86
Jul 26, 2010 09:02 AM
Lexscme
Nov 10, 2009 02:43 PM
dopeyx27
Jan 11, 2008 07:58 PM
T0ked
May 14, 2006 07:10 PM
