Older GM models DRL burnout issue
Old May 24, 2018 | 09:32 PM
FrankReynoldsCPA's Avatar
FrankReynoldsCPA
So my truck is a Canadian market vehicle that was later imported back into the US. DRL's are required by law up there. Unlike the US market F150, there is no ability to turn off the DRL's in the little cluster computer.
Well, turns out that there is. I hooked my laptop to the OBD port and fished around in the BCM and found a setting to reenable that menu item. Now I can turn my DRL's off. I've never turned them back on.
Old May 25, 2018 | 07:20 AM
Infra's Avatar
Infra
Originally Posted by Johnhav430
The fix as addressed in Bulletin No.: 00-08-42-010A is to switch to bulbs that can withstand the spikes better (12.8v v. 14v). But I don't have to be an electrical engineer like my dad to say whoa, it now goes from 27w to 31w? Isn't it v=ir?
Voltage isn't set by devices on the circuit, it's regulated to be supplied at a constant value. Although, in this case, the fact that it's not constant is what is causing issues. The higher rated voltage on the 14v bulb just adds a margin of error. Likely the only result is that the 14v bulbs will appear a bit dimmer than the 12v bulbs.
SSmith
Feb 15, 2015 07:45 AM
italiandud
Dec 8, 2007 11:33 AM
Frankr66
Dec 21, 2006 10:08 AM
wwest
Lighting
Dec 17, 2001 01:15 PM
