How a Power Steering Pump Works
Old Dec 19, 2017 | 04:58 PM
speedkar9's Avatar
speedkar9
Default How a Power Steering Pump Works
I thought I'd share my teardown of a power steering pump. Its quite interesting what's inside and how it works!
Here are a few photos of the pump teardown. This is the high pressure line and pump removed:
This is the pressure port union. The two small holes are what fluid travels through:
The flow control valve reroutes excess fluid from the high pressure side to the low pressure side. This controls how much steering boost you get through the steering rack. Mine popped out and flew away before I could get a pic, but here's a diagram:
Removing the pulley:
This is the low pressure inlet:
This is the pump separated into two halves. On the left side is where the action happens, there's a rotor that spins in ecentric cam. The rotor has vanes on it that push the fluid causing the flow.
Here's the rotor removed with the vanes. The vanes are free to move along the slots of the rotor, and therefore are pushed outward against the eccentric cam's shape by centrifugal force.
What's left is the eccentric cam and the main part of the housing, that contains the pockets directing fluid into and out of the rotor:
And that's pretty much all the components inside a Toyota power steering pump:
Enjoy!
Old Dec 21, 2017 | 10:17 AM
Hoovey689's Avatar
Hoovey689
2UR-GSE Owner
I love these break-down tutorials. The way you lay it out with the parts, is far easier to visualize keep up the good work friend.
Also congrats, I see you added an 04 Camry to the stable!
Old Dec 21, 2017 | 06:19 PM
speedkar9's Avatar
speedkar9
Thanks
Yes the 04 Camry is the replacement for my Solara, though I feel the Solara was a better car.
Tmhender82
Feb 3, 2026 12:37 AM
hidavi
Jun 11, 2016 10:36 AM
PseudoK
Oct 23, 2014 11:45 AM
tritron
Maintenance
May 6, 2007 10:01 PM
khepera
Jan 22, 2006 11:39 PM
