Do Northerners insulate their engines?
Old Dec 6, 2017 | 05:21 PM
MattyG's Avatar
MattyG
Originally Posted by riredale
No, I'm not talking about using an engine block heater. That would certainly be useful if the car is cold-soaked overnight in very cold weather--and if a power cord were nearby.
What I wonder is why the hybrid maker couldn't fabricate a thin block-hugging insulating blanket so that the block would be very slow to cool down once the engine was turned off. Up here in Oregon right now it's perhaps 40 degrees Fahrenheit during the day. Say I drive to get a haircut, the engine almost reaches operating temperature by the time I get there. I come out 30 minutes later and the temperature gauge is back on "C." With insulation it would probably have dropped only one notch or even less, and I'd be getting 30mpg on the drive home. Plus, instant cabin heat.
Yes, adding a blanket would not allow the block to radiate heat, but I have a suspicion that block cooling is only a few percent of the total heat exchange, something the radiator could easily take up.
Anyway, just a thought, but I won't be surprised to see this as standard practice on hybrids (perhaps even non-hybrids, though the gain would be less) five years from now.
What happens if you forget about such an insulator that's covering your engine block and get caught in stop-go traffic and the weather shifts to warmer temps very quickly? You'll overheat the gasoline part of the drive train. How would you fit such an insulator? There is so much plumbing under the hood that nobody is going to design a custom fit device. If there's wind chill, you'll see heat loss under the vehicle as the heat dissipates underneath the car. Might as well just put a heat wrap bubble around the whole vehicle. Or just park in an underground heated garage whenever possible.
Koma
Mar 15, 2007 02:16 PM
