is 250 cold start problems
Old Dec 16, 2016 | 12:41 PM
Dietz1968's Avatar
Dietz1968
Default is 250 cold start problems
I have a 2009 lexus is 250 AWD. When it is cold outside (belowe 10 degrees) it will start and then die out after a few seconds. After about the third try it stays running. I had it to Toyota but they could not find the problem. Anyone had this problem and were able to fix it?
Old Dec 16, 2016 | 02:50 PM
davyjordi's Avatar
davyjordi
ask the members in the 2IS sub-forum. they might be more apt to help you.
Old Dec 16, 2016 | 02:58 PM
mmarshall's Avatar
Could be one of several different things, but likely a weak or failing coolant-temperature sensor that does not send the proper signal to the engine's computer when cold, causing an overly-lean condition with the air/fuel injection on start-up. Or a dirty fuel system or injectors themselves that get plugged up and don't deliver enough fuel to the engine. That can come from using cheap, cut-rate brands of gas that don't have enough detergent-additives in them to keep the injectors clean...a practice I have long-discouraged. The IS250's V6 is known to suffer from deposit build-ups and need a lot of fuel-system cleaning.
dbarber45
RX - 1st Gen (1999-2003)
17
Nov 19, 2014 06:08 AM
phuatw
Nov 4, 2014 03:22 AM
jfmjr
Apr 11, 2012 10:48 AM
na4now
Aug 10, 2007 12:29 PM
