2017 Honda CR-V Debuts!
At least it does not have that ridiculous push-button/rocker-switch gear selector of the Pilot. But look at that central display monitor. The glass surface is so large, yet the actual viewing area is so small. Look at all that wasted real estate on both the left and right sides. Could Honda not have placed those soft switches/icons to that bit of space above the volume dial?
I knew the volume dial would come back -- it was just history repeating itself. Twenty-something years ago, the Gen1 Ford Contour / Mercury Mystique had radios with rocker switches to adjust volume, rather than a round dial. Not too many years later, the dial found its way back.
At one time, Honda was known for its simple but highly effective ergonomics.
The exterior, i'll wait till I see it in person, the interior definitely an upgrade from my 2014 , but the LCD dash screen looks too tiny, in my opinion, exterior reminds me of a Ford Edge just like the Honda Civic reminds me of the Ford , Wonder how the 1.5L turbo will be like. Hopefully they upgraded the audio systems too, they were very weak sounding on all models of the current gen.
Honda is one of the only automakers that doesn't offer a branded, premium audio system. I know that's not necessarily the absolute best audio option, but I think there is some inherent value, and performance enhancement of those Bose/Harman Kardon/JBL/etc systems, even for the mainstream non-lux cars.
Gauges look fine. Digital is the future and the awesome Honda S2000 had it right ages ago. What is wrong here is the speedo digits are too small. This is the most important piece of info to be had, and they shrunk it down. What's also wrong is this display has the inefficient diagonal "bars" that divide the area. The most wasted space comes from these. There's simply no need for them, as they go right where other important displays should have gone. New Civic as the same problem. BTW, the previous CRV's gauges were a huge inefficiency as well. The speedometer was way too large and stole precious space. Jumbo speedo gauges are rapidly disappearing from the industry, and for good reason.
Some other general points:
Overall body shape is pleasant and modern. But front end has a major overbite. Honda designers fell asleep for the lower half of the main grille. Gave the top half all the decorations and left the lower half an unfinished black hole. Rear taillights are still overstyled and feminine, as they have been on the last two CRV's and most Volvos. Honda would sell even more of these if they just made the taillights more appealing to all sexes. Round tailpipe tips are dated units. And yes.... all that unpainted black plastic at the bottom is something people should point out. Main dash vents are poorly integrated and an odd shape that do not match or mesh with all the other stack shapes just below them. Flat wood trim is a nice, modern touch on the higher trim levels.
Honda hit the major points well and this will sell very well.
(Respectfully) I have to disagree. The S2000 didn't have it right. That's one of several reasons why the Mazda Miata, (which did have it right) blew the S2000 out the door in sales-numbers, and why the Miata (and its new Fiat 124 Spyder cousin) are still around while the S2000 is long gone.
Yes, I know, but that was my point.....The Miata's simple gauge panel was one factor, among several, in its much greater popularity over the S2000.
Of course, it's possible that the average CR-V buyer might (?) be a little more tolerant of a bar-graph gauge panel than those who buy and drive small roadsters.
As for that overbite, it now seems to be a distinguishing feature on the CR-V.
The 3rd-generation CR-V had it bad.
The 4th-generation face-lifted model also went back to it after ditching it for the initial 2012 new model.
Initial 4th-generation model:
Face-lifted 4th-generation model:
Digital gauges are OK if done in an easily-readable, analog-style format. A number of vehicles are already doing that now.
Seems a bit overstayed, but no doubt an improvement all around. I think it will definitely hit its mark.
Please explain. Why are digital gauges good only if they don't look digital? I fail to understand what's wrong with having large number representing your speed right in front of you, that is clear to see immediately. Why is it better to have a needle (or a fake digital needle) pointing to a hash mark between 2 numbers? I don't see how you get a speedometer that's easier to read than what they have in this new CR-V. I understand that in the 80s, when these first came out, sometimes there was sun glare and wash out, and you couldn't really read them. But the digital display has evolved, and new color LCD style screens don't suffer from this problem any more.
The reason why I say it is hard to beat a sweep-needle design is that, when accelerating or losing speed quickly (or when the engine RPMs are rapidly increasing of decreasing, as in lower gears), it's usually easier for your eyes and brain to follow the actions of a needle sweeping up or down than to try and decode a constantly-changing set of flashing digital numbers or bar-gragh lights. IMO those electronic flashing-displays are basically gimmicks. Yes, I know that military fighters have heads-up displays that flash much of the data in the windshield, but that's done, not so much because of the electronic format itself, but to simply allow a fighter pilot, in combat, not to have to take his eyes off of what is going on in front of him to look up and down at the panel.As a rated Private Pilot (and Ground Instructor) checked out in several Cessna and Piper models, I also found that, in the cockpit, it was usually easier to deal with analog rather then digital gauges. When flying manually in IFR/hood/low-visibilty conditions, you had to multi-task and monitor several gauges at once (altimeter, airspeed, flight-attitude, directional gyro/compass, VSI (Vertical-Speed-Indicator, and others).
The reason why I say it is hard to beat a sweep-needle design is that, when accelerating or losing speed quickly (or when the engine RPMs are rapidly increasing of decreasing, as in lower gears), it's usually easier for your eyes and brain to follow the actions of a needle sweeping up or down than to try and decode a constantly-changing set of flashing digital numbers or bar-gragh lights. I.
