Quick Spin: 2014 Infiniti QX60 Hybrid
Old May 30, 2014 | 11:33 AM
JDR76's Avatar
JDR76
Originally Posted by LexFather
Gotcha, thanks for clarifying for me.
No worries.
I don't see this thing selling well at all. I read it as a huge sacrifice in engine/performance, with little to no gains in fuel efficiency, but for a higher price. Not a winning recipe in my book.
Old May 30, 2014 | 12:07 PM
Lex2InfiN's Avatar
Lex2InfiN
Originally Posted by JDR76
It really doesn't seem out of line to me. A Highlander Hybrid is 4800 pounds and is smaller than this.
I don't think you understand. According to this board, everything Infiniti puts out is junk, non-competitive with anything else in its class, overweight, and leases for 0 money down, $99/month. Didn't you get that memo yet?
Old May 30, 2014 | 01:11 PM
GSteg's Avatar
GSteg
Did not miss that at all. I do not believe the 3.5 in the Highlander weighs 200 pounds more than the 2.5 in the Infiniti. Merely pointing out that an SUV this large weighing 4600 pounds seems pretty typical and not heavier than I would expect.
The extra weight is coming from the hybrid drive-train. The Highlander has a 167hp motor for the front wheel and 68hp for the rear wheel. They're going to be bigger and heavier (duh) than the QX60's 20hp. The Highlander uses a 45kW NiMH battery. Powering the QX60's motor is a very small 0.6kW lithium pack that pales in comparison as far as weight goes.
4,600lbs may very well be acceptable, but it's not doing Infiniti any favors.
It doesn't help that when I look at QX60 Hybrid reviews, I see owners complaining about sub-par MPG. At least with the Highlander, you get an extra 30hp to move that additional 200lbs.
http://www.edmunds.com/infiniti/qx60/2014/?sub=hybrid
Old May 30, 2014 | 01:38 PM
rogers2's Avatar
rogers2
Veteran: Navy
I don't know much about the hybrid version but I was very impress with the gasoline version during a test drive. My ex gf is a dog handler and she reviewed a few suv's and this is the only one she kept talking about over and over again.
Old May 30, 2014 | 03:52 PM
Carmaker1's Avatar
Carmaker1
I've driven two very extensively (as in for multiple days) one was fully loaded. I'm unsure how this vehicle with lowest hp in class with very questionable materials is worth 50k let alone 60k. The hybrid here barely offers any improvements compared to the RX 350 to RX 450h. What impressed me most about the JX was the rear 3rd row was quite spacious and usable for a vehicle this size (I find the new Higlander 3rd row a joke for adults).
That said consumers surely have no issue with it since it sells very well but its would not be the first time a vehicle is purchased that is quite average.
Well, I definitely have not had such extended first hand experience with the JX35/QX60, like I have the past 2 generations of RX Hybrids (2008, 2010, 2013) vis-à-vis my older sister. The last time I interested myself, was when it was called the JX35. The base prices of the QX60 are $42,100 and $43,500, while the Hybrid commands only a $3,000 premium. The U.S.-spec RX450h commands over a $6,600 premium against the RX350. This may be more justifiable, considering the number improvements over the RX350. It still remains higher than the QX60 Hybrid, except in base RX350 FWD form. Likely because of the third row, Infiniti believes in the right to charge more for the QX60 FWD.
Considering the existence of a possible price floor, likely due to the directly related Pathfinder at highly equipped levels, it may not be to fair to rather chastise Infiniti based on pricing. The QX60 is already under a luxury badge and from my impression was done correctly material-wise (at least for MY2013), so the regular QX60 is already priced sensibly as against other competitors. I may be biased, as I already was impressed by the interior of my parents' QX56 and expected that the JX35 would follow similarly.
The only way it would reach over the base prices and towards a peak $61k in AWD Hybrid form is via class competitive optional equipment ($14-15k), so one should rather direct any frustration towards Infiniti's pricing of the optional extras and if the Hybrid is truly worth an extra $3,000.
If someone wants a very basic QX60 Hybrid, they can get one quite below $50k. The materials will understandably be the same as in both a basic and well-equipped version (at $61k), as Infiniti has yet to invest properly in the options of upgrading interior material appointments (sans wood accents) from initial specification. As evident of the updated QX80 (Limited), that may soon be possible.
At the moment the QX60 material quality is acceptable to me at the base price. I guess I've never expected as much at this level, as I usually would with Jaguar or Bentley.
Old May 30, 2014 | 06:04 PM
mmarshall's Avatar
I don't know if Infiniti changed the interior or materials any with the renaming of the JX35 to the Q60 (I probably should have checked one out a few days ago when I was at the Infiniti shop reviewing the Q50). But,when I reviewed the JX35, I was very impressed with the interior quality. Even its lower-priced Nissan Pathfinder brother was well-done inside.
Old Jun 1, 2014 | 02:20 PM
no need to be quite so dramatic. just about all brands here have their fans and detractors.
Hoovey689
Feb 16, 2015 02:57 PM
Hoovey689
Jan 30, 2014 11:55 AM
Hoovey689
Sep 4, 2013 07:13 PM
Hoovey689
Apr 2, 2013 06:42 AM
Hoovey689
Aug 14, 2012 07:03 PM
