It sounds like the flittering of fresh $100 bills, or at least that's what we assume it sounds like. DDMWorks in South Carolina has released the first 700 conversion kit for the Ariel Atom 2. By strapping both a turbocharger and a supercharger to the Ecotec 2.0-liter four-cylinder engine, the company has managed to wring a full 700 horsepower from the mill. Of course, the internals required a bit of massaging. DDMWorks threw in Darton mid sleeves, ceramic-coated Wiseco pistons, H-beam Carrillo rods and ARP hardware throughout. A set of 1,100-cc fuel injectors keep the engine fed, and a custom air-to-water heat exchanger keeps the supercharger output serviceable. The turbo, meanwhile, relies on an air-to-air intercooler.
DDMWorks went with 275-mm wide rear tires on custom 17x9 wheels to get the power to the ground. The company has even supplied the driver with the option of three power levels, including 450 hp, 575 hp and the Full Monty. Sound perfectly sinister to us.
"power is nothing without control". I promise you there is way to much power in that car to control it. In fact it probably would be hard to keep straight just flooring it in a straight line
Seeing the Ariel Atom 500 had about 864 bhp per tonne, what does this come out to be? If it comes out to be like 1210 bhp per tonne, that is more insane than a SSC Tuatara at 1083 bhp per tonne.
