premium fuel
Old Feb 15, 2008 | 08:14 AM
simonrac's Avatar
simonrac
Default premium fuel
I own a 98 GS400 with 120,000 miles on it. Recently, one of my friends who own an SC400 told me that he doesn't put premium fuel in his car because it doesn't make a difference.
I'm a little paranoid about switching to regular. Does it impact the longevity of the vehicle? The performance is a smaller concern for me.
Thanks!
Old Feb 15, 2008 | 08:24 AM
DallasLex's Avatar
DallasLex
All Toyota engines are designed to recognize the fuel octane and adjust air/fuel mixture automatically to get smooth operation from both premium and regular.
The main reason Toyota recommends premium in Lexus engines is that all spec.s related to these engines are based on premium(which indeed does give optimal performance). Both of my previous LX470's ran perfectly on regular gas(exactly like the Land Cruiser), but I still chose to use premium for that optimal result.
Try regular for a week may be and see if there's substantial drop off in performance, then go from there. I just don't think longevity would be affected by regular gas.
Old Feb 15, 2008 | 09:44 AM
Overclocker's Avatar
Overclocker
G35x - RWD/AWD goodness
CL Folding 500,000
Hi simonrac, and welcome to Club Lexus.
I'd like to mention that we also have a section devoted entirely to the 2nd gen GS. And, this is a hotly debated subject that you can find many threads about if you search.
Now with that out of the way, DallasLex has done a good job touching on the subject. I'd also like to post up another members thoughts on this that 19psi just wrote about in the LS forum, but I think is worthy of being posted here.
Should you run premium fuel? Yes and no, explained.
See this topic raised all the time and I thought maybe I could explain it so everyone will understand what is going on. Maybe a moderator could sticky it?
PLEASE take your time and read this thoroughly, even twice if you have to. I realize it's quite a bit to take in for some people without a performance background.
WOT= Wide Open Throttle
TDC= Top Dead Center (Where the piston is at it's maximum height during the compression stroke)
I'm going to use 87 as regular, and 93 as premium. I realize that in different parts of the country there are different ranges, so you'll have to apply it to what you have.
First of all, octane is the measure of the fuel's resistance to burning during the combustion process in the cylinder.
So 87 burns more easily than 89 which burns more easily than 93.
The only reason for high octane is to make maximum horsepower and torque because of it's resistance to pre ignition, otherwise known as knock, or pinging.
Our engines make the most power at high rpms, close to redline, and obvoiusly at Wide Open Throttle (WOT). Under those conditions, pre ignition will occur with low octane fuel, which will be detected by the knock sensor. The ecu(computer) will then retard timing, preventing pre ignition, but also holding back Horse Power and Torque.
The main reason we see timing pulled on a high octane rated engine is because of compression. Most Lexus engines are high compression. The high compression requires that the fuel not "blow up" before it is scheduled to, because the compression itself will cause the fuel to want to burn, even without a spark. Low octane fuel will start to burn too far before the piston reaches TDC. This produces knock or more properly pre ignitin. If allowed to burn uncontrollably, this will stress the piston and rod to the point of failure, as the rod is being phyically forced UP by the crank , while the combustion reaction is trying to force it DOWN. This is how we see rods sticking out of the side of the block.
As a safeguard, the knock sensor sees this pre ignition and informs the ecu. The ecu responds by retarding ignition timing; making the spark occur later in the compression stroke. This will prevent the low octane fuel from burning ahead of time, saving the engine from damage while restricting power.
Over the course of a few drive cycles, the ecu see the continued pre ignition, and places the timing map on a permanent retarded state so that it won't be continually pulling timing from the high performance map.
If you then start using premium, the ecu will see the lack of knock, and slowly start giving timing back. Or if you know you will be using 93 exclusively again, you could reset the ecu which will start out again on the high performance map. (Resetting of the ECU is accomplished by pulling the EFI Fuse in the engine bay)
For maximum power, we want the spark and combustion process to occur at a precise moment before the piston reaches TDC. This is what is known as ignition timing. Too far, and we pre ignite. Too late, and we lose power and torque.
To is it ok to use 87? Yes, if you just cruise along all the time and granny drive, then you can use 87 all the time with no ill effects. If you don't go full throttle to redline regularly, you'll be fine. Just don't expect maximum power if you one day need to floor the throttle to get out of the way of a semi truck.
Link to original thread
Old Feb 15, 2008 | 09:46 AM
Koma's Avatar
Koma
CL Folding 25,000
Tell your friend with the SC400 he's incredibly lucky and should stop doing that.
The 1UZFE I know cannot bear lower octane gas regularly, it'll cause the engine to knock.
Honestly it's a .30 difference per gallon, for a fill up (roughly 16-20 gallons) would cost you a $6 difference. It's worth it in my opinion to fill up with premium octane gas if your car can actually benefit from the higher octane. Lower octane gas will produce worse power which turns into less fuel efficiency.
Don't make the switch, it's not worth screwing up your engine for $6 a tank.
rogerh00
NX - 1st Gen (2015-2021)
142
Sep 15, 2021 04:31 PM
menty
Jun 12, 2021 05:01 PM
sunnyside
RX - 3rd Gen (2010-2015)
Jun 8, 2012 08:17 PM
archangels
RX - 1st Gen (1999-2003)
69
Sep 8, 2009 10:33 AM
dougjohn
Aug 16, 2004 10:56 AM
