How to improve my Gasmileage?
afternoon or in the evening, what should be a gallon is not exactly a gallon. In the petroleum business , the specific gravity and temperature of the fuel (gasoline, diesel, jet fuel, ethanol and other petroleum products) are significant. Every truckload that we load is temperature-compensated so that the indicated gallonage is actually the amount pumped. A one-degree rise in temperature is a big deal for businesses, but service stations don't have temperature compensation at
their pumps.
2. If a tanker truck is filling the station's tank at the time you want to buy gas, do not fill up; most likely dirt and sludge in the tank is being stirred up when gas is being delivered, and you might be
transferring that dirt from the bottom of their tank into your car's tank.
3. Fill up when your gas tank is half-full (or half-empty), because the more gas you have in your tank the less air there is and gasoline evaporates rapidly, especially when it's warm. (Gasoline storage tanks have an internal floating 'roof ' membrane to act as a barrier between the gas and the
atmosphere, thereby minimizing evaporation.)
4. If you look at the trigger you'll see that it has three delivery settings: slow, medium and high. When you're filling up do not squeeze the trigger of the nozzle to the high setting. You should be pumping at the slow setting, thereby minimizing vapors created while you are pumping. Hoses at the pump are corrugated; the corrugations act as a return path for vapor recovery from gas that already has been metered. If you are pumping at the high setting, the agitated gasoline contains
more vapor, which is being sucked back into the underground tank, so you're getting less gas for your money. Hope this will help ease your 'pain' at the pump.
5. Do not top off your gas tank, when the pump shuts off, do not keep trying to add more gas..................a friend who owns a gas station says that by doing th is, you are actually giving the next customer a $1.00 worth of gas. The gas you pump stays in the hose and never makes it to your tank...........good to know.
6. *my own* Catch the bus.
Most fuel injector cleaner you buy will not make a dramatic difference because the instruction label tells you to use certain amount per gallon(s) of fuel. But what they dont tell you is that the concentration is pretty diluted. This saves them a lawsuit if one should ever put too much and blames the brand for recommending large dosage.
I ran a fuel injector cleaner through my car using a F.I canister. It's fed directly to the fuel rails with a 50:50 concentration of gas and addictive. This is very concentrated, but it takes a high amount to get the injectors cleaned. It's not a butt dyno or anything either because there was a difference in gauge pressure at the injectors before, during, and after the cleaning.
My highway fuel economy did gain 2mpg. Mind you the previous owner has always taken the car to the dealer for maintenance, and nothing but Chevron 91 octane has been in the tank.
I also have 150 lbs of sandbags in the trunk for the winter, and I'm not doing too bad, lost only a mile to the gallon and gained some traction.
I would try the fuel injector cleaner or some sort. Your car is 8 years old. I'm sure you have some sort of buildup in your engine by now.
