View Poll Results: which setup will perform and sound better
A
14.29%
B
71.43%
C
14.29%
D
0%
Voters: 7. You may not vote on this poll
Muffler setup
Old Mar 27, 2006 | 09:52 PM
PR FIEBRU's Avatar
PR FIEBRU
Default Muffler setup
which will perform and sound better
Old Mar 28, 2006 | 01:09 AM
kietlander's Avatar
kietlander
wow thats some skill u got there.lol just playing with you.
Old Mar 28, 2006 | 05:42 AM
4TehNguyen's Avatar
4TehNguyen
theres going to be no difference b/t X and H, they arent connected in flow like stock is
Old Mar 28, 2006 | 10:02 AM
Koma's Avatar
Koma
CL Folding 25,000
Try two y-pipes welded together. Least amount of bend but not completely straight through.
Old Mar 28, 2006 | 10:29 AM
Lexmex's Avatar
Lexmex
Agree with you on this one.
Old Mar 28, 2006 | 10:38 AM
92 SC400's Avatar
92 SC400
Nice Etch-A-Sketching!
Old Mar 28, 2006 | 12:12 PM
DASHOCKER's Avatar
DASHOCKER
Stick figures? which one is the female lol Ok, I would think the x pipe configuration sounds the best. getting that myself
Old Mar 28, 2006 | 05:28 PM
BUSTN's Avatar
BUSTN
You need to read up on the differences of the x and h pipes.Their is a difference.
The firing order of all production V8s, regardless of make, has one cylinder in each bank that will fire within 90 degrees of crankshaft rotation of another cylinder in the same bank. This occurs twice during completion of the entire firing order. These two cylinders will be exhausting almost simultaneously into the same exhaust manifold system.
Full-length four-tube headers help separate these pulses until the collector is reached. If this is a full race car running "open exhaust", you will notice the collector dumps into a short open pipe at least 2.5 times the size of the header pipes, or the header pipes dump direct without a collector. This is done to avoid the conflict of pressure caused by the timing of the 2 counter firing cylinders, which will create back pressure and degrade torque, horsepower and general performance, especially at higher RPM.
On a full exhaust system, after the header tubes dump into the collectors, the two close firing cylinders are fighting each other for space in the collector and exhaust pipe. The result is reflected pressure waves traveling back up the exhaust system, backpressure, lost power and poor economy.
At the same time two cylinders exhaust in one bank, there is no activity in the opposite bank. The traditional H-pipe equalizer allows some of the excess pressure to bleed over to the 'quiet side' of the exhaust system, resulting in some low and mid-range torque improvements. At high RPMs, however, in traditional exhaust systems, the gases cannot bleed across the H-pipe fast enough to help power significantly. Performance systems with the H pipe design, attempt to over come this by using a shorter cross over pipe which is also slightly larger in diameter as the main exhaust, then would be used in a standard exhaust.
To overcome the power loss of "over loading" the H pipe design, Exhaust manufacturers came up with the X pipe design, which features a tangentially Siamese crossover junction to synchronize exhaust pulses. The X-pipe concept is to split the flow in the crossover junction, so the pressures on both banks will be equal and pulse-free after the crossover, regardless of the rpm. Volumetric efficiency and power are therefore improved at all engine speeds. The negative aspect to the X pipe design is, because of the crisscrossing of the flow stream, harmonic pulsations will develop on some systems at certain RPMs, which will be perceived as a buzzing or humming sound.
A newer concept is a "Channel Pipe", where as two pipes are welded together in parallel with a baffle in between them which allows for mismatched pressures and pulses to cross to the idle side while allowing full, uninterrupted or redirected flow of the exhaust stream through the system.
Old Mar 28, 2006 | 07:21 PM
Koma's Avatar
Koma
CL Folding 25,000
Could you explain this channel pipe design a little more, I'm interested.
Old Apr 5, 2006 | 08:38 AM
PR FIEBRU's Avatar
PR FIEBRU
thanks for the info. I am guessing x pipe would do the best. Now I am a little confused on the channel pipe. would that be two pipes going straight the the back but at the same time are both welded together ??
ISFPOWER
IS F (2008-2014)
58
Feb 25, 2014 02:39 PM
GS4hunnit
Performance
Dec 4, 2012 07:10 PM
madmax98
Feb 8, 2009 01:13 AM
menty
Jan 28, 2009 06:42 AM
indypwr
GS - 1st Gen (1993-1997)
Dec 6, 2002 01:31 AM
