Rx350 2025 Cross bar setup
Old Jan 26, 2025 | 12:06 PM
hahmed's Avatar
hahmed
1st Gear
Default Rx350 2025 Cross bar setup
I got 2025 RX350, it has roof flush rails. There is no hole or screw place in the roof rails to setup crossbar, the side dent also looks not very deep. I am worried if the crossbar will be stable enough without any hole or point where the crossbar is well attached.
Old Jan 28, 2025 | 09:51 AM
RA030925's Avatar
RA030925
My '24 RX 350 came with the cross bars (which I did not want but were already included from the factory). There are four indentations where they are mounted. The car came with filler panels if I choose to remove the cross bars. Your should have indentations in the rails that would pop out to install the cross bars.
Old Jan 29, 2025 | 08:45 AM
Kensterfly's Avatar
Kensterfly
Not sure if we’ll get the rails on our RX350 when we get it. We had them installed at the dealer when we bought our 2020 RAV4. We have never used them but “it looks right.”
Old Jan 29, 2025 | 09:37 AM
RA030925's Avatar
RA030925
They do give the car a sporty look.
Old Feb 3, 2025 | 08:17 AM
Criticalman's Avatar
Criticalman
Default Adapter for Yakima rack ?
Are adapters needed to mount Yakima cargo carrier on 2023 RX350h ?
Old Sep 7, 2025 | 07:48 PM
TexasTiger's Avatar
TexasTiger
10th Gear
I got my 2025 RX350h two weeks ago and have been searching for cross bars. I am also wondering how to remove the covers of the 4 indentations on the flush mount rail. Any help is appreciated.
Old Sep 8, 2025 | 06:56 AM
SymbioticSix's Avatar
SymbioticSix
The 4 covers pop right out. If you look at the closely, there is a small slot centered, n the outside of the plate. A thin screw driver or credit card will pop them right off, easy peasy.
Old Sep 8, 2025 | 10:32 AM
TexasTiger's Avatar
TexasTiger
10th Gear
Thanks for the info. I will give it a try. I haven't found the cross bars. If I pop up the cover, will I be able to put it back? Thanks again.
Old Sep 8, 2025 | 10:39 AM
SymbioticSix
Yep, they pop right back into place as easily as they come out.
Old Sep 15, 2025 | 07:34 AM
nowlen's Avatar
nowlen
It might look right on a RAV4, not so much on an RX (IMO). And the added wind noise of crossbars is unnecessary, especially if you're just adding them for 'looks'.
ArtNouveau
Nov 30, 2023 02:19 PM
situman
GX - 2nd Gen (2010-2023)
Apr 12, 2022 10:25 AM
29er
RX - 3rd Gen (2010-2015)
Jun 7, 2019 01:34 PM
SFocLA
RX - 4th Gen (2016-2022)
19
Apr 18, 2016 03:19 PM
