Canada For events in Canada.
wheel 'damage'
Old May 1, 2007 | 08:43 PM
legomaniac's Avatar
legomaniac
Default wheel 'damage'
so i finally got around to putting my stock wheels back on... and... well... just see for urself... i have no idea what it is and it won't come off w/ scrub'g or w/ wheel cleaner
they've just been sitting in my garage in bags since they came off for my winters from kal-tire
Pic 1
Pic 2
edit: left this info out:
sorry, i left some info out... basically it looks like mold... and i think it's under the clearcoat cuz when i tried to clean one of them, some clear plastic stuff flaked off the wheel
also, when u feel it, some spots feel perfectly smooth like there's nothing there but others feel hard like, i dunno, tartar? and others yet feel kinda gummy...
Old May 1, 2007 | 09:19 PM
UberNoob's Avatar
UberNoob
are they physical damage?
if cosmetic only, try claybaring it
see if that takes the "paint" out
Old May 1, 2007 | 09:34 PM
legomaniac's Avatar
legomaniac
first post edited for more info
Old May 2, 2007 | 08:55 AM
narfy's Avatar
narfy
that looks like your wheel is starting to oxidize... polished aluminum faces tend to do that... try a scrubby pad and some comet first, and then run some mcquires metal polish over it and a buffing wheel... that should get rid of most of it...
Old May 2, 2007 | 09:02 AM
legomaniac's Avatar
legomaniac
confirmed to be corrosion by someone i wouldn't question... *sigh*
Old May 2, 2007 | 10:34 AM
skperformance's Avatar
skperformance
Looks like they were laying down on the concrete and slid across it. Thus it fracture the clear coat and is now peeling and showing as white aluminum salt corrosion.
Old May 2, 2007 | 03:18 PM
legomaniac's Avatar
legomaniac
i should clarify, a veteran at my autoX club confirmed that it's corrosion and that it's UNDER the clear coat... so even if i go at it, i'll be spending quite some time on it... *Sigh*
Old May 7, 2007 | 10:51 AM
W. David's Avatar
W. David
You're not alone on this one man......pulled the L-sportlines out of the garage yesterday afternoon to put them on the car....the lip on one of them looks identical to your wheels! I didn't know what it was either, so i went at it with some CLR, and then decided to pull out a razor blade to test my theory of calcium buildup (from what though???). Neither worked, but this thread confirms my second hunch.
Plan on taking it into the rim shop on Monday.....
fishhuntnc
GX - 1st Gen (2003-2009)
Dec 23, 2013 05:59 PM
Nick@Autogeek
Automotive Care & Detailing
Aug 19, 2011 12:55 PM
Keppie
Jul 7, 2009 08:37 PM
lfrers
Wheels, Tires & Brakes Forum
Jun 3, 2006 09:29 AM
17gs400
Oct 18, 2005 08:11 PM
