Build Threads Details on Club Lexus LS400 owner vehicles
David's 1998 Lexus Ls400
Old Aug 30, 2017 | 09:47 AM
  #91
Scraape's Avatar
Scraape
Old Aug 30, 2017 | 09:49 AM
  #92
Scraape's Avatar
Scraape
and it might be tough to see, but heres the damage to my ABS wiring in the drivers side fender well
Old Aug 30, 2017 | 10:42 PM
  #93
hotdawwg's Avatar
hotdawwg
Yikes, glad that is all that happened. How has the ride been with the Function and Form Coilovers
Old Aug 31, 2017 | 06:39 AM
  #94
Scraape's Avatar
Scraape
the ride is great now that i can actually raise the fronts to the height I wanted! Had to contact Function & Form and they sent me a longer shock body which I installed and now my coilovers can go low or high in the front!
Old Aug 31, 2017 | 09:39 AM
  #95
ultm8mind's Avatar
ultm8mind
You're right you can hardly see the damage man...
Old Sep 1, 2017 | 06:05 PM
  #96
hotdawwg's Avatar
hotdawwg
Interesting. How much longer where the shock towers? Have a part number? I am getting ready to order mine soon.
Old Sep 1, 2017 | 06:58 PM
  #97
Scraape's Avatar
Scraape
i don't remember how much longer the new ones were, but if you run into the same issue simply contact function and form and they will send you longer shock bodies for the front shocks and you just have to pay $20 for shipping. They claim you won't be able to go as low with the longer shock bodies in the front but that is nonsense, I can still adjust mine pretty damn low if i wanted to.
Old Nov 13, 2017 | 05:19 PM
  #98
Scraape's Avatar
Scraape
anyone know why this wire might be installed? Doesn't look factory to me. Runs to the positive battery terminal and the fuse box.
Old Nov 13, 2017 | 10:48 PM
  #99
TeckJoel's Avatar
TeckJoel
I’d say trace the wires but my guess would be some sort of tracker or something along those lines
Old Nov 14, 2017 | 06:17 AM
  #100
Scraape's Avatar
Scraape
theres nothing to trace. it's simply that green wire in the picture lol, i dont understand why its there but i'm developing corrosion on my positive battery terminal and thinking that might be linked to it
Old Nov 14, 2017 | 09:54 AM
  #101
Scraape's Avatar
Scraape
Just pieced together a 90k Timing Belt/Water Pump Kit for my LS. It's creeping up on 270k and timing belt was last done at 100k, so i think it's just a little past due, haha.
I opted for pretty much all OEM toyota parts, with the exception of the idler #1 & idler #2 which were koyo.
1. Toyota OEM Timing Belt 13568-09070 $43 shipped
2. Idler #1 Roller Tensioner Koyo 13505-0F010 $30 shipped
3. Idler #2 Bearing Koyo 13503-0F010 $28 shipped
4. Toyota OEM Hydraulic Tensioner 13540-50030 $39 shipped
5.
Toyota OEM Front Cam Seals (2) 90311-71002
Toyota OEM Front Crank Seal (1) 90311-A0001
$70 shipped package deal for the seals
6.
Toyota OEM Water Pump 16100-59275-83
Toyota OEM Water Pump Gasket 16271-0F010
$96 shipped package deal
7.
Toyota OEM Thermostat 90916-03100
Toyota OEM Thermostat Gasket 16346-50010
$19 shipped package deal
8. Toyota OEM Serpentine Belt 99366-H2230 $45 shipped
9. Toyota OEM Radiator Cap 16401-50071 $25 shipped
Also, added to the list:
10. Fan Bearing Bracket Toyota OEM Part # : 16307-50011
there's a couple things that I would now add to this list. You can buy a new pulley with bearings already pressed in, or you can save $ and use your existing pulleys and press out and in, them being:
Serpentine Belt Tensioner Pulley Bearing 17mm shaft diameter, 40mm OD, Quantity:1 bearing, Mcmaster-Carr Part #: 5972K44
Toyota OEM Part # (for pulley & bearing): 16603-0W010
Serpentine Belt Idler Pulley Bearing 12mm shaft diameter, 37mm OD Mcmaster-Carr Part #: 5972K86
Toyota OEM Part # (pulley & bearing):
Old Nov 30, 2017 | 11:47 AM
  #102
Scraape's Avatar
Scraape
so i tried removing that green wire and putting everything back together. My clock, radio, climate control, and entire dash lights stopped working altogether.
Re-installed the green wire and they all work again just fine. Makes me wonder what is going on, remedy for a bad ground maybe?
Old Dec 1, 2017 | 02:03 AM
  #103
Sc0pe's Avatar
Sc0pe
I feel like something between the interior fuse and a constant power wire failed, and the only/easiest way to fix was jumping/bypassing via that wire.
Old Dec 2, 2017 | 06:02 AM
  #104
Scraape's Avatar
Scraape
anyone know which transmission cooler line is which that goes to the radiator?
I'm installing a magnefine inline transmission filter and i want to put it on the return line. Just trying to figure out which is the outlet from transmission vs the return line to transmission
Old Dec 2, 2017 | 01:54 PM
  #105
Scraape's Avatar
Scraape
well i figured it out i think.
also, super glad i invested in one of these creepers. Harbor freight ftw
